Different Front Speaker Ports on Receiver (A+B) what do I use?
Nightsbane
Nightsbane Posts: 100
http://i87.photobucket.com/albums/k144/moonlightfilms/sp1.jpg
Here is a picture of what is on the back. I am getting polk monitor 50's in today, and wonder how they should be wired up to this correctly. I have a DG820 Sony receiver.
Thank You!
Post edited by Nightsbane on
  • apphd
    apphd Posts: 1,514
    edited May 2009
    Do you have an Adobe reader so you can view .pdf files? If so
    here ya go:
    http://www.docs.sony.com/release/STRDG820_install_EN_ES_FR.pdf
    Or if you really want to put your read on:
    http://www.docs.sony.com/release/STRDG820_EN.pdf
    Don't get so worried, it's easy. Post back after reading if you still have questions,
    treitz3 Posts: 19,956
    edited May 2009
    Either one. Just make sure that you are using either A or B and that you have the wire hooked up to the one you are using. In other words, if you hook it and the mains up to A....make sure that you run A and not B.
  • Nightsbane
    edited May 2009
    So I guess I just pick one then, not sure of why they put two there
  • superjunior
    superjunior Posts: 1,632
    edited May 2009
    I'd use the binding posts A, I'm not a big fan of the little inserts on B, plus you can use bannana plugs with the posts for a more solid connection. As treitz said, just make sure you have your mains set to A and not B in the receiver, should be good to go
    jr
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited May 2009
    Nightsbane wrote: »
    It's so that you can hook up multiple pairs of speakers to it. You can either have two pairs in the same room to switch between, or you could have the second pair in a different room. It's a pretty handy feature IMO.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
