Bi-amping
potee
potee Posts: 610
edited May 2009 in Speakers
Please explain what bi-amping is and how and why it's done. also why are there four (4) wire conectors on some speakers. Thanks. I didn't think I was a noob but guess I'am.
Post edited by potee on
  • Solumnus
    Solumnus Posts: 48
    edited May 2009
    Search bi-amping on Google. Or search the forum to get a better understanding. Bi-amping is basically hooking up 1 speaker to 2 different amps. There are 4 binding posts for bi-amping or bi-wiring your speakers. (Remove any jumper plates or wires before attempting either of these things.) Generally the top posts will feed the higher frequency drivers(tweeters, mids), and the bottom post will feed the lower frequency drivers(woofers).
    Toshiba 62HMX85
    Panasonic DMP-BD60
    Xbox 360 with HD-DVD
    Pioneer VSX-9130-TXH-K
    Polk Audio CSiA6
    Polk Audio RTi10's
    Polk Audio RTi4's
    Polk Audio RTi6's
    Polk Audio PSW505
  • potee
    potee Posts: 610
    edited May 2009
    I only have (!) one amp so for the time being I won't worry about that. Thank You
  • Pinktulip7
    Pinktulip7 Posts: 249
    edited May 2009
    TV :>Panasonic TC-P55VT50
    RECEIVER :> HARMAN KARDON AVR 7300
    FRONT :> L & R :> POLK RTI A9 500 W
    AMP :1> PARASOUND HALO A21 250 W
    AMP :2> EMOTIVA UPA-1 200 W
    CENTER :> POLK LSiM 706c 250 W
    SURROUND SIDE :> POLK RTi A3 150 W
    SURROUND REAR :>POLK FXI A6 150 W
    DVD PLAYER(HD) :>TOSHIBA HD X-A2
    DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
    POWER CONDITIONER :> PANAMAX M5400-EX
    SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
    SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
  • Hilbert
    Hilbert Posts: 316
    edited May 2009
    Here's a good place to start reading:
    http://www.polkaudio.com/education/showanswer.php?question_num=53
    Maybe it will inspire you to get another amp. Or not.
  • potee
    potee Posts: 610
    edited May 2009
    Hilbert wrote: »
    I most likely won't get another amp, but after my new speakers have a couple hundred hours on them I may try bi-wireing. Decideing to buy new speakers has turned into one hell of a learning curve for me just glad I found this forum.
  • Serendipity
    Serendipity Posts: 6,975
    edited May 2009
    Basically it is using more than one amp to power your speakers.
    If money is not a concern, FOUR monoblocks would be awesome - one for the left channel highs, one for the left channel lows, one for the right channel highs, and one for the right channel lows.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited May 2009
    Solumnus wrote: »
    Actually, bi-amping does not necessarily have to come from differents amps but can come from different outputs of a single amp provided your amp can accomodate such. IE: If you are not using the "B" output on your amp, you could use to bi-amp your fronts for example.
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • Serendipity
    edited May 2009
    TECHNOKID wrote: »
    Correct me if I'm wrong, but I don't think that is bi-amping.
    I can use the Zone 2 output of my AVR to do the above, but the current is still limited by the power supply. I know that most AVR's output the rated power (e.g. 100W/ch) with two channels, but with seven channels driven the power output is lowered. Then that using multiple channels (or "B" speaker outputs) wouldn't provide much of a difference.
    If the output transistors for the front channels are already using up 100% of the power supply, using two more channels (Zone 2) would cause the front output power to decrease. At least that's what I notice with my AVR.
  • TECHNOKID
    edited May 2009
    appadv wrote: »
    However, if this is your only option (using "B" channels for example) while not providing you with substantial power gain it would at least provide you with the benifit of woofer and tweeter isolation and sharing of the work load amongst your outputs (not as much stress on an output transistor/IC and its dedicated circuitry).
    Unfortunately, most people look/think power gain when considering bi-amping when in many cases, the aspect that actually benefits the most is the isolation since power gain is usually very insignificant since you need at least double the power to gain only a 3db. When you are seeking quality of sound for example, isolation has much more impact then power increase. We have to realize that our speaker passive cross overs are somewhat limited and do have leakage which provide some of the unwanted frequencies leakage, which can cause distortion and/or also cause more stress on our speakers.
    If you look at bi-wiring for example, there is no advantage in power gain what so ever but it provides somewhat better woofer/tweeter separation due to twice the lenght in the cable (thus unwanted frequency dissipating and not returning back as strongly). I am not recommending or discouraging bi-wiring in any way shape or form but simply use it as an example to emphasize the important but overlooked separation benifit of bi-amping or tri-amping (which is a separate sub in addition) which seperates the 3 basic ranges (Low-Mid-High). Of course, having dedicated power amps for each individual frequecy rages will in the overall provide better quality in sound since you will not have to drive them to their limit to produce the desired power level of the sound.
    Cheers :)
    DARE TO SOAR:
  • dpowell
    dpowell Posts: 3,081
    edited May 2009
    appadv wrote: »
    Agreed and you are also limited by the input wattage the AVR can handle.
  • Systems
    Systems Posts: 14,873
    edited May 2009
    appadv wrote: »
    It isn't, that's essentially biwiring and IMO no real advantage as both outputs will be driven by the same output section of the amp.Also if the unit uses an A+B switch instead of separate A and B switches, the high and low sections of the speaker will be hooked up in series,not a good thing.
    Testing
    Testing
    Testing
