Repair my Paradigm PS1200 amp?
Vdr1973
I was wondering if anyone knows how to do repairs to amps?
I have a Paradigm PS1200 that has an amp that will not turn on,after removing the amp i found 2 burned resitors and was wondering if there is anyone out there that knows how to repair or should i try to get a replacement amp?
Post edited by Vdr1973 on
You could probably get the resistors replaced for cheap. I had some resistors go bad on a sub before and it cost my around $30 to get fixed.Pioneer 50" Plasma (PDP 5080 HD)
Pioneer Elite VSX-01
Panasonic BD35
PS3
Monster MP HTS1600 Power Conditioner
Paradigm Monitor 7's v3 (Front)
Paradigm CC370 v3 (Center)
Paradigm ADP 370's v2 (Surround)
Polk Audio Rti4's (Back)
Paradigm PW 2100 V2 (Sub)
Coming Soon: 5 channel or 7 channel amp. -
Just find a repair shop in your area with a good reputation, it would probably be cheaper than shipping both ways.
Call Paradigm and find the authorized repair shop in your area. That will be your best bet.
Replacing just those resistors probably won't help. Multiple resistors don't just fail for no reason - there could be an active component (i.e. power transistor) that failed and took the resistors with it.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
good advice,most people dont realize this -
Well talked to my local Paradigm dealer and asked if they could servive the amp and was told Paradigm will only sevice it if i had original receipt.Does that sound right to any of you?Anyways so i dropped it off at a local electronics repair shop hopefully they can fix it,if not iguess ican try my very first Diy.
