Pio SC-07 Best Price
01, 9130 and 1018 are pretty much the same receiver (some will argue that adding 12V trigger, THX sticker and Elite sticker is worth extra couple hundred bucks).
You forgot the ICE amp. I have not owned any of these but I am pretty sure the 1018 does not belong in this group, can't say about the 01 and 9130. The 1018 is a great AVR at its price and intended market, but I think it's an apple to oranges thing comparing it to the Elites. -
ICE amp is only used in SC 05 and SC 07 from Pioneer line-up and quite frankly I cannot afford it at this point in time. 01 and 03 use "regular" class A/B amplifiers.
If you do the research, you will see that 1018, 01 and 9130 are the same receiver +/- some small features, but the internals, front panels, rear panels, including the Class A/B amp are exactly the same.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Sorry even though you quoted reno I read it as though it pertained to the whole thread "Pio SC-07 Best Price" and mufsoman's question as to "I have a Pioneer VSX-0094TXH. Is there any advantage to upgrading to a SC-07?"
I think the 01 used Wolfson WM8728 DAC and since the DAC used in the 1018 is not listed I am assuming (I know bad thing to do) it was using a cheaper one. I guess I would need to listen to a 1018 beside a THX Select2 01 Elite before I could compare the sound, regardless of what is in them. -
I finally decided to get 03
. It's 499 USD in the Michigan store, which is the closest one to Toronto. Would make about 735 CDN after shipping and taxes, all included. Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
Decided on 03 and put a local offer on Onkyo TX-SR805... We'll see...
B&W CDM1-SE fronts
B&W CDM-CNT center
I'm sure you'll be happy with either of those recievers. I am definatley happy with my Pioneer regardless of not having ICE amps."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
Rough guess.. It's a good price in Canada for the 03.
