Help with receiver/amp question.
Ultraner
Ultraner Posts: 3
edited May 2009 in Electronics
Hope this is in the right forum. Im working on a new HT system , and have a few questions about powering the speakers im thinking of getting. I currently own an older bose accoustimas 6.1 system that came with an onkyo TX-SR601 receiver. While im aware of this receivers evident lack of features, and power, im heavily considering getting an amp as well to make the speakers sing. Now my question is can I add an amp to this receiver? Im aware that I need a pre-out on the receiver to do this and this receiver does have one and only one. Its a sub pre-out, is it possible to hook an amp to a pre-out for a sub and still hook up a powered sub somehow? Im not totally against a new receiver as ill be obviously scraping the rest of the system and starting anew.
The system im looking at is as follows.
Rtia5 fronts
CsiA6 center
Dsw Pro 500 Sub
Fxi A4 surrounds
This settup brings me close to my budget, So do I ditch the old onk and get a newer one and maybe add the surrounds later. Or do I stick with the onk and get an amp if possible? All suggestions are greatly appreciated and im sure if you look to your left of the screen youll see how big a noob I am at this. Thanks in advance.
Post edited by Ultraner on
    Toolfan66 Posts: 18,184
    edited May 2009
    Dump the receiver, get one with preout's so you can add the amp later. There are a bunch out there to look at. What is your budget for a receiver? that way we can help you in the right direction new and used.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited May 2009
    That's a nice setup you're putting together there. You should be very happy with it.
    What I'd recommend is getting the speakers first. The Onkyo will do fine powering them for a while. The RTi's are pretty efficient speakers, and don't take a lot of power to sound good. An external amp will definitely make them sound a lot better though.
    After that, I'd look into upgrading to a newer AVR that has pre-outs, and then eventually add an amp.
    No, you won't be able to add an amp to that receiver. The subwoofer output is an LFE output, and the only signal that goes to that output is the Low Frequency Effects, hence the LFE designation.
    By the way, welcome to Club Polk.:)
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Ultraner
    Ultraner Posts: 3
    edited May 2009
    Well, I suppose it could be a 3.1 system for a while and I could dump anywhere between 800 and 1000 dollars on a receiver, and later add surrounds and an amp. The fronts, center, and sub put me right at 2000 dollars. Thanks for the quick reply to!
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2009
    Welcome to Club Polk Ultraner. Tool & Curt have started you in the right direction. You are putting together a great system that will keep you happy for years to come.
  • Ultraner
    Ultraner Posts: 3
    edited May 2009
    Wow you guys are fantastic. Comfortablycurt you answered my question about my receiver, thanks a ton. Ill deffinetly give this alot of thought and that sounds like a great start. Im still up in the air about getting the surrounds immediately, and maybe putting that money towards the receiver. It wouldnt take me long to come up with the funds for the surrounds if a grovel at the wifes feet for a bit hehe. Thanks again!
  • renowilliams
    renowilliams Posts: 920
    edited May 2009
    Welcome to the forum. It sounds like your making great choices for speakers. I have a similar set up and am very happy with it. Keep in mind that your rtia5's will need approximatly 100 hours burn in time. Your in for a treat.
    Tim
    P.S you hang out in here long and you'll be groveling at your wife's feet a lot....lol
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • rallyshark
    rallyshark Posts: 417
    edited May 2009
    You could get away with spending 5-600 bucks on the receiver IMO. There are alot of decent receivers with good power and pre outs that could be had for that much or even less. Both new and used. Most of which would be quite an upgrade over your current receiver. You would also be able to decode the later formats:) I'm sure someone will come in with some more "detailed" suggestions on which ones. Good Luck!:D
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS3(games/media server)
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
    When rapture comes, can I have your car?
    edited May 2009
    Hi,
    Mid level HDMI, Tru-HD Audio recievers for Rtis?
    Harman Kardon AVR 254,AVR 354
    Onkyo 706
    Pioneer 1018 (not this year's model, the 1019--it loses the pre-outs, I think--plus a lot of power as well--go with last year's model).
    or an entry Pioneer Elite.
    All of these have their own sound so you should give them a listen. Also look for a good 'used' deal. A number of people here are getting ready to sell their Onkyo 805/6s...for example.
    Should be able to get any of these on 'sale' in your price range.
    Good Luck.
    cnh
