Universal Headshell
haimoc
Will a new universal headshell (Sumiko HS-12 Universal Headshell for example) work with vintage turntable Denon DP-37F?
I've been finding an answer to this question, but I could not find any. Could anyone please help?
Thanks.
Thanks.
Post edited by haimoc on
I am using audioquest u headshell with my Technics. I do not think there are issues with doing this on your Denon.Speakers: SDA-1C (most all the goodies)
Thanks. I will give it a try.
I was confused with different headshell models were used in different vintage Denon turntable models.. The DP-37F was installed with PCL-30 (same as PCL-50). -
hearingimpared wrote: »
Thanks for the contact info. I'll email them first.
I also sent Denon email and still waiting for their reply. -
haimoc, you can also contact lpgear.com and ask them if there's an option for a half inch mount cartridge for that tonearm. They were really helpful and responded quick with me & setting up my Denon DL-160 when I had my Audio-Technica.
Linky:
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=DENONSTDP0037F
There's a contact link to the left of the page....Those plates came in for the dustcover btw. I'll be going down to pick them up shortly.
Mike
Thanks, Mike. Will do.
