HT Projector choices
thsmith
thsmith Posts: 6,082
edited May 2009 in Electronics
A friend at work was asking me about projectors but I know nothing about them so I thought I would see if fellow polkies in the projector know could help.
He is torn between these two projectors.
Panasonic PT-AE3000U $2500 or the Epson Home Cinema 6500UB Projector for $2500 (after $500 rebate).
Pretty good writeups at this site
http://www.projectorreviews.com/1080p-projector/1080p_projector_award_winners.php
He would be interested if any other 'new' information out there that would either help him decide or change his choice altogether. He is going with a really big screen, so he is leaning toward the EPSON.
Screen desired dimensions:
Main uses: Equal sports in HD and BR movies.
Gain: 1.2
16.9: 135" diag, 66x118". Throw distance of 18'1", eye height 46". Center of screen 58". Top 90". Bottom 24"
2.39:1 133" diag, 52x125w. Throw distance of 18'10", eye height 46". Center: 54 2/3", top 80 2/3". Bottom 28 2/3".
Note: he will adjust the throw distance using the zoom/refocus.
Thanks for any info to help him decide.
Post edited by thsmith on
  • Serendipity
    Serendipity Posts: 6,975
    edited May 2009
    They are very close in PQ. However, I would go with the 6500UB. The Epson 1080UB (last year's model) is also a great performer.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2009
    In its best mode the Epson would be brighter and for such a large screen you're going to need all the lumens you can. I would even go as far as suggesting a Da-lite Hi Power screen to get even more output from the projector. The Panasonic is ok, has lens memory so you can run a scope setup without the need of a lens/sled assembly.
    If these are the only choices then the Epson, if the budget expands, JVC RS10.
  • thsmith
    edited May 2009
    Thanks appadv and Sherardp !
    Keep it coming Polkies, BTW this guy just bought some nice used RTi10s and a Polk center.
  • Grimster74
    Grimster74 Posts: 2,577
    edited May 2009
    I've owned the Epson Home Cinema 1080 (right before the release of the 1080UB) and its a great projector. For a screen of that size I would definately go with the Epson due to the Epsons being real light cannons. Seen a few of the Panny projectors before and the picture it throws was right on par with the Epsons but the Epsons in my opinion are much brighter projectors for sure.
  • Sherardp
    edited May 2009
    Grimster74 wrote: »
    So what do you own now?
  • Grimster74
    edited May 2009
    LMAO!!!!! Oops, guess I forgot to mention that, JVC HD1, stole it from some poor **** that knew if he sent it to me I'd pull the trigger on it. Thanks again bro for looking out for me!
    Rob
  • engtaz
    engtaz Posts: 7,669
    edited May 2009
    Go with the Epson.
    engtaz
  • dpowell
    dpowell Posts: 3,081
    edited May 2009
    Epson makes a great projector. I've had one in the past but went with a Mitsubishi last time around due to the price point but that doesn't seem to be an issue here.
  • mshan242700
    mshan242700 Posts: 823
    edited May 2009
    Another good site for projector reviews: http://www.projectorcentral.com/
