Help with Amp Selection, please
barneyrubble
I have a somewhat unique situation that I wouldn't mind having some advice for.
First a short history - A few years back I bought a Sony STR-DE825. Loved it from the beginning and have enjoyed it since. When I moved to Japan, I brought it with me, not knowing that the power coming out of the wall sockets was different in both voltage (only 100) and number of cycles (either 50 or 60). The good news is that it didn't seem to affect the performance of my system at all. Living in a shoebox apartment didn't allow for much 'cranking' of the volume, so perhaps that's one factor in my current predicament.
Late last year I bought a house and since I've moved in I enjoyed many evenings of excessive-volume-listening to my favorite music. (My speakers are Bose 301 in the front, some Toshiba somethings in the back and an Aiwa as the center). No problems, other than mediocre sound quality.
About a year and a half ago, I visited one of friends from college who had bought a set of Polk speakers which were driven by some cheapo $150 receiver. What surprised the heck out of me was the quality of the music coming out of those little tiny speakers sitting on his bookshelf. So I decided that an upgrade was in order, beginning with speakers. I bought a set of LSi7's, hooked 'em up, and was literally blown away at the difference.
The next thing I did was take Polk's recommendation about bi-wiring. I changed the ohm setting to 4 (which I have since learned is a very bad thing to do to Sonys), turned off surround sound, cranked it up, and was amazed again at the difference. So I decided more volume was needed. I ran the volume at about 3.5 for a couple of hours. I don't need to tell you that it got hot. REAL hot. The next time I went to use it I found out that the receiver had short circuited.
Herein lies the problem....I've been reading about all the great amps available in the States, however they are unavailable in Japan. Pretty much, I am limited to the following: Sony, Yamaha, Pioneer, Marantz, and Onkyo. (There are other brands but they don't have a good reputation here - Technics and Panasonic (which are the same company but branded differently here), Sansui, etc..)
My question is, of the brands I've listed, does anyone have some advice as to which would be the best for my LSi7s?
My primary concern is that they are 4 ohms and most amps are 6 or 8. I think that ohm-matching must be important, although I am not an expert.
Post edited by barneyrubble on
check out that Outlaw in the flea market. Good price on it also.Shoot the jumper.....................BALLIN.............!!!!!
A McIntosh MC252 should be available in Japan and would make your speakers sing!
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
See my signature buddy, I'm in Japan also. All you need is power converter. That will give you 120/60 just like the USA. I run a converter to the wall and power my monster 7000MKII with it. My converters both have analog gauges on them so I know exactly what they are putting out. Where in Japan are you? Shoot me a PM, but if you're military or contractor weight is going to kill most amp deals. Check out Sunfire, the Outlaw Monoblocks. PM me if needed.Shoot the jumper.....................BALLIN.............!!!!!
This is the right person for the info you need.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Thanks for the advice.
Sherardp, I'm in Sendai. (apparently I'm not able to PM you until I have a total of 10 posts). I was hoping to stay away from power converters. I've had some experience with them, both good and bad. I also probably should have mentioned that my budget is somewhat limited right now, especially since I bought a used house that hadn't been maintained at all in like 15 years.
You mentioned something about a flea market - where is that?
If you have some time, maybe you could PM me and I could pick your brain for info.
Meanwhile, what I'm thinking about now, is just buying a late model used receiver for a couple of hundred bucks to drive things until I can save enough to do things properly. To that end, I am looking at three Pioneers on Yahoo auction - VSA-AX1AH, VSA-AX2AH(may be a Japan only model), and a VSA-AX4ASi. -
From what I've seen around here I'd look at one of the new pioneers with the ice amps in them. From personal exp. I could recommend a Marantz, Great brand, great quality sound and built rock solid, can't remember if all of their gear is 4 ohm stable, but I think if you're looking at them you would be able to check. Good luck, and listen to what sheradp has to say.
Hey Barney,
Agree would suggest you pick up a new Pio Elite SC-07. Get yourself a good power converter, and power conditioner or Power strip, which ever the budget allows and run with that. The new Elites are very good. PM sent.Shoot the jumper.....................BALLIN.............!!!!!
