pc's , digital sound and cd ripping ??
ward91
Hello all, don’t seem to be being much “forum” stuff recently but i just had a question that’s been floating in my mind for a while now.
I apologise if it has been previously addressed but;
when a cd is ripped to the pc to a wav/other format does the cd transport (in the pc) effect the quality of the rip in terms of jitter (or anything else)??
and if you use the pc as a digital output , say to your avr would the pc soundcard's quality have a major effect, if any on the fidelity of the digital signal in converting it(if it even has to) to a pcm signal or say a Dolby signal to be sent to your avr.
cheers ed
cheers ed
ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
Post edited by ward91 on
Wow - what excellent questions. Hopefully someone will pipe-in.
No real answer but some things to consider:
--First off: if your compressing the audio, your quality settings would be far more significant than anything jitter or you sound card.
Theoretically, burning at a slower speed, and not playing while importing
might cutback on effects of minor 'jitter'. -- never tested could be a myth.
You could also take advantage of options built into whatever software you use. for example iTunes has an option labeled "Use error correction when reading Audio CD's" I've always assumed this was some sort of a noise filter.
Lastly: if you really want high quality, avoid the 'middle-man' (compressor) completely, just drag the files to disk, play them in their native digital state. (You WILL need a lotsa disk space -- I find this worth it for Classical, and Jazz.if you use the pc as a digital output , say to your avr would the pc soundcard's quality have a major effect
GREAT QUESTION: I've always assumed so, but sadly output sound quality doesn't seem to be compared in any reviews I've seen.LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability. -
I can tell you from personal experience that sound card quality is important. Last year I bought a Asus Xonar D2X soundcard as I mainly use my pc to play video to my tv through the avr. The difference was very noticable over my Soundblaster Audigy 4 card. I use the optical out to the avr.
I can highly recommend this card. Here is a link;
http://www.bit-tech.net/hardware/2008/01/13/asus_xonar_d2x_pci-express_soundcard/1"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
Wow, that is a nice sound card.I just might get that to replace my Xfi fatality pro.I dont see more than a couple games that use the x-ram my card came with.That was a waste IMO.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
With ExactAudioCopy, the cdrom quality matters less. It adjusts the read
speed for best results.
I use an external DAC. I used a pro (audio recording) style audio card for
a short time, and the cheap usb DAC was better."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson
