Setting up zone 2 & 3 on Pioneer Elite SC-05
ckphoto
I need some help/guidance on setting up additional zones with my Pioneer. On my previous AVR's I just used speakers "B" but on the Pioneer I am running 7.1
and speakers "B" are the rear surrounds and are being used in my HT. I assume I need to get a power amplifier and hook it to the zone 2/3 preouts. If I am correct can someone please recommend a cheap power amp ($200-$300) I will be running Bose AM in one room and cheap outdoor speakers on my deck.
Thanks,
Chris
Thanks,
Chris
Mitsubishi WD-73736
Pioneer Elite SC-05
Xbox 360
Sony PS3 80GB
Velodyne minivee
Rti70s
Csi40
4-Fxi50s
Monster PowerCenter HTS 3600 MKII
Harmony One
Pioneer Elite SC-05
Xbox 360
Sony PS3 80GB
Velodyne minivee
Rti70s
Csi40
4-Fxi50s
Harmony One
Post edited by ckphoto on
You may have to PM mantis on this one, but if you're using speakers in a 7.1 setup I dont think you can use them as zone two speakers at the same time.Shoot the jumper.....................BALLIN.............!!!!!
