Polk RM302 , 7302 and RM201
melove51
Hi,
I'm looking for a new center channel, Polk RM302 or RM7302.
I'm also looking for some surround sound speakers, Polk RM201.
Let me know if you have anything comparable to, i'm open to suggestions.
Thanks.
Thanks.
Post edited by melove51 on
melove51 is your set-up only 3 speakers at this point and you are trying to slowly build it up to 5.1 or 7.1?
Options:
If the RM30 are still available at that pricing, you could get a couple more pairs, use one as front center and one as rear center and 2 as surround and then you could sell your RM200 serie lowner or find some more if that is for another room but I can tell you the RM20/200 seems to be pretty rare and their pricing never seemed to go down that much compare to the RM10 & RM30, I guess they must have sold pretty good and stock might have been gone before they thinking of replacing the model (RM8 series I think???).
I don't know if you tought about it originally when first shopping for speakers but one of the surround bar product could have possibly be the answe for you???
Cheers
DARE TO SOAR:
Thanks for the reply.
They actually had another RM30 so I just picked that up for my center channel.
I have some small Infinities right now for my rear that are OK, but I'll just keep my eyes open for upgrading those.
On another note, I was looking at putting my RM30s on speaker stands, like 16" ones, but I was just trying to get ideas on how to do it with some safety since they are so long and there center of gravity if higher.
I would love to wall mount them, but my room is kind of awkward.
