lsi15 best speaker cables
Nacken23
Nacken23 Posts: 100
Hi all i have just received my new lsi15s and they look awsome still havnt heard them yet though. Anyway i need to buy cable for them and need advice. What thickness do i get and what brand? I have heard blue jeans speaker cables being mentioned what do you guys think ? Also i want them at a reasonable price
Post edited by Nacken23 on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    I like Audio Quest type4's. Buy used;)
    Ben
    treitz3 Posts: 19,983
    edited May 2009
    Or a pair of AQ CV-8's that come with a bat pack and yes, buy used to save a lot of dough.
    The best thing about buying used is that you can sell them for pretty much what you bought them for and try a different flavor until you find the pair that has the best synergy with your rig. One question for ya' though. What's reasonable to you?
    For some on here, reasonable is 3K.....for others reasonable is $50 smackers.
  • Nacken23
    Nacken23 Posts: 100
    edited May 2009
    Any more suggestions?
  • Pauly
    Pauly Posts: 4,519
    edited May 2009
    Can never go wrong with Signal Cables.
    Life without music would
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited May 2009
    http://www.audiogon.com/cgi-bin/cls.pl?cablspkr&1247836348&/MIT-Shotgun-S3-10ft-BiWire-pr--NEw
    Before Jesse suggests these I thought I'd beat him to it.
    Buy one pair of these and they will save you future money because they'll be the last cables you will buy or need.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited May 2009
    I have some MIT AVt 2 biwires that you are welcome to purchase. Also have some all spade Signal Cable Biwires, Cardas Crosslink, and Tara Labs RSC 1000 biwire. Like them all, but not 100% attached to any of them.
    Hit me up via PM if you have interest. I'm sure I have something that would suit your need and pricepoint.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Lowell_M
    Lowell_M Posts: 1,660
    edited May 2009
    Pauly wrote: »
    +1 for signal cables. Much more open and detailed than the Canare 4S11 I was using and not too bad of a price.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
