Lexicon 512
jerryj12
jerryj12 Posts: 451
edited May 2009 in For Sale (FS) Classifieds
This is one excellent Ht amplifier,but it needs a new home.( 2 channel itch. ) Minor scratches due to age. Great overall shape. Very powerful.
Description: Five-channel, solid-state, power amplifier. Output power into 8 ohms: 120Wpc (21dBW), 20Hz-20kHz, <0.5% THD (FTC). Output power into 4 ohms: 200W minimum continuous (23dBW). Frequency response: not rated. THD+noise: 0.007%, 20Hz-20kHz, ±0.1dB. Intermodulation distortion: 0.002%, 60Hz+7kHz mixed 4:1. Noise: -107dB, input shorted, dB below rated output, 20Hz-20kHz bandpass. Input impedance: 15k ohms, balanced or single-ended. Input sensitivity: balanced input regular, 2V in for 100W into 8 ohms; balanced input in +6dB switch position, 1V in for 100W into 8 ohms, unbalanced input, 1V in for 100W into 8 ohms. Output impedance: not given. Damping factor: not given. Power consumption: typically 100VA, all channels idle; 900VA, all channels at full power into 8 ohms; 1600VA, all channels at full power into 4 ohms.
Dimensions: 17" (425mm) W by 5.25" (131.25mm) H by 17" (425mm) D. Weight: 75 lbs (33.8kg)
Asking 1250.00 + Shipping
This Amp was made for Lexicon by Bryston ( 9b Thx )
Post edited by jerryj12 on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    Another vouch for Jerry. The amp is very clean and solid.
    Ben
  • george daniel
    george daniel Posts: 12,096
    edited May 2009
    Thats one serious A$$ piece of gear. Buy from Jerry with confidence,,I have had a coupla/three transactions with him,, he's good people.Good luck with the sale.
  • jerryj12
    jerryj12 Posts: 451
    edited May 2009
    Thanks George. You are right, my mouth is watering for those 9s.
  • ben62670
    edited May 2009
    You have polluted his mind with his 2 channel adventure. This is one serious amp for LSI's.
    Bump for Jerry.
    Ben
  • danz1906
    danz1906 Posts: 5,144
    edited May 2009
    Great Looking Amp-Good luck with the sale.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • jerryj12
    jerryj12 Posts: 451
    edited May 2009
    danz1906 wrote: »
    Thank you sir,:D
  • ViperZ
    ViperZ Posts: 2,046
    edited May 2009
    Correct me if I am wrong, but isn't it just a rebadged Bryston?
    So basically you will be getting a high-end amp for much less than what you'd pay for the same Bryston (with less warranty on Lexicon).
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • Ethancf
    Ethancf Posts: 478
    edited May 2009
    Just bought some LSi/Fx's from Jerry...he's a great guy to work with.
    THE SYSTEM
    Polk Audio LSiM 707 Mains
    Polk LSiM 702 f/x Surrounds
    Polk Audio LSiM 706 C Center
    SVS SB-17 Ultra Subwoofer
    Rotel RSP-1582 Pre/Pro
    Rotel RMB 1585 Amplifier
    Oppo UDP-205 Blu-ray Player
    Samsung PN64D550 64" Plasma
  • unc2701
    unc2701 Posts: 3,587
    edited May 2009
    ViperZ wrote: »
    Yep, and here's the thing about that warranty. Bryston wouldn't have a 20 year warranty if their amps broke very often- they'd be out of business in no time. My friend that sells them has only heard about one going back to the factory once- shipper dropped it, and something got knocked loose. Bryston still fixed it for free.
    Backburner:Krell KAV-300i
  • ViperZ
    ViperZ Posts: 2,046
    edited May 2009
    unc2701 wrote: »
    I know that. Bryston factory is not that far :p
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • george daniel
    edited May 2009
    Somebody buy this thing already so Jerry can get the 9's that OTHER people are looking at. :)
  • jerryj12
    jerryj12 Posts: 451
    edited May 2009
    Price bump...... How does 1100.00 shipped ( Conus ) sound? This price will be good for 24 hrs. Then its off to AGon.
    Thanks,
    Jerry
  • george daniel
    edited May 2009
    I don't think that it will last long on Audiogon at this price--good luck with the sale.
  • george daniel
    edited May 2009
    ViperZ wrote: »
    I checked into that,,and yep,,it's a Bryston. I think that Bryston is one of those that belongs in the " Man Amp" category. Good luck with the sale, helluva' deal.:)
  • jerryj12
    jerryj12 Posts: 451
    edited May 2009
    I'm over at Jerry's right now listening to this amp as it is powering Carver amazings,,and it sounds very good.Actually extremely good,,I came over to take pictures as it is about to be listed on A'gon. I would be remiss if I did not post/bump this. For the asking price(1100.00 shipped),it's a steal. FYI, it's a rebadged Bryston.
    Thanks----geogre
  • ben62670
    edited May 2009
    Hey George you forgot to sign out as Jerry:)
    Ben
  • jerryj12
    jerryj12 Posts: 451
    edited May 2009
    Oops,,, anyhow,, have you heard this thing with the Carvers?
  • ben62670
    edited May 2009
    I am calling now:)
    Ben
  • mdschlayer
    mdschlayer Posts: 209
    edited May 2009
    I'll take it. PM sent.
    LSi15's, LSiC, LSiF/x's, LSi7's, vr3 crossover upgrades, SVS PC-12 Plus, SVS SB-16 Ultra, Marantz AV8805, Parasound amps, LG OLED65C9PUA, Clarus Crimson, Signal Cable, Atlas Cable, Shunyata and Synergistic A/C conditioning, dedicated Cardas 30A and Furutech 20A AC lines, Box Furniture, Solid Tech ROS, Symposium roller blocks
  • jerryj12
    jerryj12 Posts: 451
    edited May 2009
    Sold.... Thank you sir.
  • ben62670
    edited May 2009
    he stole it.
    Ben
  • daboyz
    daboyz Posts: 5,207
    edited May 2009
    ben62670 wrote: »
    he stole it.
    Sorry Ben,it says "sold" not "stole".;)
  • george daniel
    edited May 2009
    congrats o the sale,,to both of you.
