Does anyone have this crossover on therir RTA 12B???
geppy1
Does anyone have this crossover on their RTA 12B?? If so what tweeters came with yours?? Thanks,Keith
Post edited by geppy1 on
Mine is a older crossover. It came with peerless with the pin hole. The blue cap looks like it was replaced. My white caps have another component in parallel. C5 is missing.engtaz
Those caps look original. The blue metal can type were standard issue. This is an absolute guess, but I'd say sl2000 tweeter.
I had (2) x-overs from 5B's an older one with fuses (yellow and black caps) using the sl2000 tweeter. Also had a newer x-over with poly switch and it had the blue metal can type caps also used the sl2000.
Not very scientific.............YMMV
P.s. Have you looked at the schematic's?"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Hi, Thanks men for your responses. Yes they are all original. I have spent alot of time researching RTA 12s I will try to write more detail tonight as it is just very screwy. Early 84 is outright bizare. I know of 12Cs made two months before 12Bs and so on. There are 5 different croosovers for the top and 3 different ones in the box.
