New Harman Kardon Amp??
AudioFilet
Anybody know if HK's new amp will be sold in the US??
You can see it here:
http://www.harmankardon.com/product_detail.aspx?Region=EUROPE&Country=DK&Language=ENG&cat=AMP&prod=HK%20990/230&sType=C
2 Channel rig:
LSi9"s (modified xover's) & HSU Sub
Harman Kardon HK 990 Amp
Onkyo C-S5VL SACD
Music Hall MMF 5.1
Furman Elite 15
HT rig:
HK AVR-745 & Polk Monitor Series
Onkyo C-S5VL SACD
Music Hall MMF 5.1
Furman Elite 15
HT rig:
Post edited by AudioFilet on
Not sure but I want one...
Power Requirement : AC 220V – 240V/50Hz
It does look pretty nice and the specs are respectable otherwise."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Face is right that's Euro current on that model. But it looks like a great solution for 4ohm loads in an all-in-one box (for Europeans, that is).
The new Harmans for the U.S. are similar to last years models..and only run 120W/Channel in 8 ohms and only about 40 Amps Instantaneous, as opposed to 100 amps for this model and 300 watts/channel into 4 ohm? That's impressive!
cnh
Pulls 800w at the wall, XLR inputs, AD1955 DACs
Doubles down at 4ohms (150x2 @ 8ohm, 300x2 @ 4ohms)
Good signs ...
The also have a matching CD player HD-990 (XLR too) designed to link up with amp and lock it's clock with external clock in amp -
Most likely will not make it to the US. I have seen this happen before with HK. They offer a nice amp over seas and you have to jump through hoops to get one in the US.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
"Mine" I might get this when I go home for the 2 channel rig. When I get home if anyone wants this amp, let me know and I will send it to you. All you will have to pay is the exchange rate and shipping. Might be a little pricey but this thing's a beast.
I'll be home in NovemberReceiver: Marantz SR7002
Fronts: Canton Chrono 509 DC
Center: Canton Chrono 505 CM
Surrounds: Canton Chrono 502 SP
Sub: SVS PC12-NSD
TV: 40" 1080i JVC Multisystem LCD(upgrading to 50" Samsung LED)
Blu-Ray: PS3
DVD: Pioneer DV-420V (HDMI)(for PAL DVD's)
Audio/Music: MacBook Pro hooked up thru HDMI
Gaming: PS3 (oifvet0608) XBOX 360 (JAYtheVET)
Cables: Inakoustik Reference -
If I had to downsize from separates, this would be top of the list. I'd just have to run the 220V circuit :0-Ignorance is strength -
Why do the exclusive Asian/European models always look better than the ones they offer us? And not just HK.
That's a good point...I often peruse the international sites of the likes of HK, Denon, Onkyo and so forth. For example Onkyos in Asia offer a Gold model--I can understand that...a bit gaudy for the American market but considered attractive and more expensive looking in Asia?
The gold units look awesome. I'm getting sick of silver/grey.
Sweet! HK makes good stuff.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D
