HK AVR254 Volume problem
daboyz
I can get sound but I have to turn the volume basically to full blast. Am I forgetting to adjust something or is this refurb a piece of crap?
Post edited by daboyz on
Please disregard - Having a severe senior moment - it helps when you unplug the EZ set microphone otherwise it thinks you're listening to headphones.:o:(
LMAO! Don't worry...things like that happen to me and I'm only 22. As long as you remember to put your pants on before you leave the house it's been a good day.:p
In reality though, that refurb HK is a piece of crap. I'll swing by and pick it up tomorrow so it can be disposed of properly. It would integrate nicely into my HT.;)The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Thats hilarious.:D
Glad you got it figured out.
Nick -
LMAO!!! I did the same exact thing with my 247!!!!! I almost hopped in the car and drove to H/K I was so pissed... Then... realized I was a moron.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
Yes, I am a moron.:D
Must say though that all things are working great and am very impressed with the on screen display. All I need is to try out a Blu ray with DTS and I'm golden.
Curt - Keep the dreams going..........;)
