my system
hello all i have been a member for a little while but do more reading then posting thought i would post some pic of my system just to see what you all think my sig has a component list all polks are hooked up with knuconcepts 10 gauge Kl3 speaker kable room is 14x32 rti4 are ceiling mounted with omni mount 20'smy friends all ask why 2 subs and when they sit down the first time to watch a movie and it makes the jump out of thier chiar i get a good chuckle and then they understand let me know what you all think thanks
onkyo 805
rti8 front
csi3 center
fxi3 surounds
rti4 back surounds
2 carver m1.0T fronts
and subs
5-marantz ma 500
110" screen
mits 1500hc
2-psw1000
rti8 front
csi3 center
fxi3 surounds
rti4 back surounds
and subs
5-marantz ma 500
110" screen
mits 1500hc
2-psw1000
Post edited by rednks1 on
Nice!!! Are you in Colorado or from Colorado?
I just noticed the Avalanche banner that's why i ask.
Larry. -
big time avs fan yes i am in colorado windsoronkyo 805
rti8 front
csi3 center
fxi3 surounds
rti4 back surounds
and subs
5-marantz ma 500
110" screen
mits 1500hc
2-psw1000 -
Where did you get the speaker hangers for the RTi4's, I do like the way they hang.
omni mounts at ultimate electronics they actualy work realy well i think around 40 eachonkyo 805
rti8 front
csi3 center
fxi3 surounds
rti4 back surounds
and subs
5-marantz ma 500
110" screen
mits 1500hc
2-psw1000 -
Thanks, These may work in the bedroom. I just don't have the time to make any at work.
Larry. -
Nice setup. a little Marantz and Carver power all right.engtaz
I like the setup, what projector are you using? The only thing to recommend is some cable management since your cabling is shown in your pics, and fixing your light before you blow something. Perhaps taking that down and putting in some recessed can lights. If you want to achieve the ultimate PQ with your projector recommend you paint the screen wall and ceiling using darker colors if possible. With a white colored room like that, you have tons of light reflecting back to your projector and are losing PQ with some wash out. Try it, I know you'll notice a difference. Other than that, enjoy.Shoot the jumper.....................BALLIN.............!!!!!
Nice System-Dual subs-Way to Go:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
thanks for the feedback and yes i need to clean up the wireing but it is in the basement and i can control the lighting very well the walls are actualy gray
i just havent decided how to cover the front wall yet but the picture is very clear coming from the mittsubishi projector hc1500 it is only 720p but it will accept a 1080p signal movies from the sony bluray look outstanding:)onkyo 805
rti8 front
csi3 center
fxi3 surounds
rti4 back surounds
and subs
5-marantz ma 500
110" screen
mits 1500hc
2-psw1000 -
Very nice. Dual rocks!Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
