To Spike or Not Spike 1.2 TL's
michaeljhsda2
michaeljhsda2 Posts: 2,200
edited September 2011 in Vintage Speakers
Any improvement/degredation in bass response if I spike my 1.2 TL's? Speakers are sitting on carpet with padding over a concrete basement floor. Thanks for any input.
Mike
SDA SRS 2.3TL's
SDA 2B TL's
Post edited by michaeljhsda2 on
«13456
    F1nut Posts: 51,703
    edited May 2009
    Spike those suckers. I recommend Mye Sound spikes, none better.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2009
    Here's the link for Mye Sound spikes.
    http://www.myesound.com/
    I use them on my 1.2TLs.
    Toolfan66 Posts: 18,006
    edited May 2009
    Thanks for the link. I was going to be asking this same question for mine.
    treitz3 Posts: 19,959
    edited May 2009
    Spike those bad boy's!
  • erniejade
    erniejade Posts: 6,321
    edited May 2009
    Listen to them on this one. I got the ones from Mye on my 1.2 and it did make a difference on the bass for me. It made them much tighter then just having them on the floor without anything.
  • thsmith
    thsmith Posts: 6,082
    edited May 2009
    Would anyone have recommendations on which Myes for SDA-1Cs on H/W floor. Size, shape and how to mount ?
    F1nut Posts: 51,703
    edited May 2009
    The big pointy ones with the floor protectors. You'll need to order T-nuts (1/4"-20) from somewhere like Parts Express and make sure you order the same thread pattern from Mye Sound.
  • michaeljhsda2
    edited May 2009
    I asked the question "Any improvement/degredation in bass response if I spike my 1.2 TL's?"
    Jesse said "spike those suckers" and others chimed in as well. All I gotta say is
    OMG, the bass response has dramatically improved and that's an understatement. If there's a tweak to be done on these speakers this would be it.
    Excellent suggestion. Thanks guys.
    Mike
    SDA SRS 2.3TL's
    SDA 2B TL's
  • thuffman03
    thuffman03 Posts: 1,325
    edited May 2009
    Spike them!
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • hearingimpared
    edited May 2009
    Mike
    Excellent!!!
  • BIZILL
    BIZILL Posts: 5,432
    edited May 2009
    i never thought about doing this before for some reason. ya'll may have just convinced me. i'm gonna have the foreman in our cnc dept whip me up a set...someday, anyway.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • hearingimpared
    edited May 2009
    Do it sooner than later B it really does enhance the bass response of your speakers.
  • BIZILL
    BIZILL Posts: 5,432
    edited May 2009
    dang, i may just have to plan it this weekend for monday. i assume the brass is used for anti-corrosive properties, yes? seems that brass will be a bit weak at the tip. brass is semi-maleable. obviously i wouldn't create anything that comes to too fine a point.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • hearingimpared
    edited May 2009
    BIZILL wrote: »
    Brass is the BEST!
  • megasat16
    megasat16 Posts: 3,521
    edited May 2009
    Oh Hell, These things are as expensive as the speakers itself. I wonder any cheaper alternative you guys could recommend?
    Never mind! I was looking at the wrong page for the pricing.
    The pricing for the spike products is at
    http://www.myesound.com/Points_n_pads.html
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
    edited May 2009
    Anybody have the lenght and diameter of a spike that would be best. I was thinking 3/4" in diameter and about an inch in length, minus the thread of course. I was also thinking with a 180lb speaker if i should just make them 1" in diameter and 1 1/4" in length.
  • thsmith
    edited May 2009
    megasat16 wrote: »
    For SDA-1Cs Oaks on H/W would it be best to have the 5/16" or 1/2" spikes?
    How would you install the T-nuts without damging the base (oak) if the 1Cs ?
    I want to do this but am nervious about drilling or hammering something into the base. I assume I would remove the factory buttons on the base and place the spikes in buttons locations.
    F1nut Posts: 51,703
    edited May 2009
    BIZILL wrote: »
    No, it's used for it's damping qualities.
    Every spike I've seen, no matter if it's brass or not, has an extremely fine point. The Mye Sound points are ice pick sharp.
    F1nut Posts: 51,703
    edited May 2009
    thsmith wrote: »
    Use the 1" daimeter spikes. Yes, you have to drill a hole, but only about 3/4" deep for the T-nuts. The T-nuts I have from Parts Express require a 5/16" drill bit. The buttons are too close to the corners, measure back about 1.5" from the corner to locate your center point.
  • BIZILL
    BIZILL Posts: 5,432
    edited May 2009
    no doubt? how's 'bout aluminum. the good stuff. 6061 or what not.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • hearingimpared
    edited May 2009
    BIZILL wrote: »
    I've used aluminum cones under my gear and found brass to be the better damper. Carbon fiber is even better but I don't recommend putting them under a 180 lb speaker even though I've never tried it, it is just my opinion based on using carbon fiber cones under some of my gear.
  • BIZILL
    BIZILL Posts: 5,432
    edited May 2009
    well, i'm hopin' we have some spare brass laying around work. doubtful. otherwise i'll try either steel or aluminum. anything's gotta be better than the factory 1.2tl feet on uneven padded carpet.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • thsmith
    edited May 2009
    Thanks, I will look into the 1"s. I may comeback after looking at PE t-nuts for confirmation I am buying the right ones.
  • thsmith
    edited May 2009
    F1, I do not find 1" diameters spikes. Here are the ones I was referring too at mye. The second from right is the one I am thinking I need. Are you referring to something different?
  • george daniel
    george daniel Posts: 12,096
    edited May 2009
    Guy's, I need to spike my 1C's,, so those of you who are going to do so,,please post here,if you would,as the t nuts come in packs of 50ea IIRC,, so I'll be happy to buy some from ya'll.:)
    F1nut Posts: 51,703
    edited May 2009
    Yes, the second from the right has a 1" daimeter. Tell Grant you want the 1/4"-20 thread pattern on that one.
    F1nut Posts: 51,703
    edited May 2009
  • BIZILL
    BIZILL Posts: 5,432
    edited May 2009
    my brizoes, you are only mentioning t-nuts for those who don't already have feet on their sda's, correct? OP was started for spiking the 1.2tl's. and the spikes on myespikes or what not oughtta screw right into the old feet female threads, yes?
    just clearing up any confusion. if i'm confused, others may be as well. so let's nip this in the bud.
    the feet i'm gonna try to have made will be like the second one from the right on that pic as well.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • thsmith
    edited May 2009
    Excellent FI. I will be ordering on Monday. I take it for the t-nuts you drill the hole and hammer into base?
    Once I get everything I want to mach up where I plan to install them, take a picture and post here before I commit to drilling.
    George, I will buy 50 and shoot you 8, ok?
    F1nut Posts: 51,703
    edited May 2009
    That is correct. All of the SDA's that came with screw in feet/spikes have the T-nuts already installed. The thread pattern is 1/4"-20.
    Correct. It's very simple.
