SDA2 Vs SDA-1C
Marty913
Marty913 Posts: 760
edited May 2009 in Vintage Speakers
I have SDA2's (5 driver) from 1986 and have a possible opportunity to pick up a pair of SDA 1C's. I'm going to rebuild the xovers on the 2's but was wondering about the value of maybe picking up the 1C's and keeping the 2's as surrounds or selling them to a friend. Or just skipping the purchase and sticking with the 2's.
I guess what I'm looking for is opinions on which set (sound-wise) would be the better "keepers". I haven't even researched 1C's so I'm not even sure of their benefits (or not). Do they have two dimensional drivers, two xovers, etc.
Thanks everybody.
Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica
Post edited by Marty913 on
    heiney9 Posts: 25,433
    edited December 2007
    1C's all the way. They are newer have better cabinets, drivers and a more refined SDA soundstage. Each generation of SDA used better materials and the concept was furthered each time by a lot.
    IMO, the 1C's are the gem of the entire line for many reasons. The big SDA's are nice but the 1C's are about perfect for many situations.
    If you 2's have the dimensional tweeter you owe it to yourself to hear/own a later gen pair of SDA's.
    my .02c
  • Joe08867
    Joe08867 Posts: 3,919
    I have original series SDA2's and once I disconnected the dimensional tweeter they started sounding almost identical to the 2A's.
    IMHO I would go with the 1c's. They have a little bit of everything going for them.
    You could use the sda2's for surround but you would need to change the tweeters to match the 1c's.
  • avguytx
    avguytx Posts: 1,628
    1C's are the ones to get. I've had them and loved them but I also have a pair of SRS II's and it didn't make sense for those great 1C's to do "closet time". If I wouldn't have gotten the SRS II's, the 1C's would have been the main speakers.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
    F1nut Posts: 51,778
    I agree with my esteemed colleagues, get the 1C's.
  • george daniel
    george daniel Posts: 12,096
    1C's,, take it from one who learned the hard way,,good luck.:)
  • danger boy
    danger boy Posts: 15,722
    1C's and they'll put a nice smile on your face :D
    PolkFest 2012, who's going>?
  • ben62670
    ben62670 Posts: 15,969
    I concur with post above. Get the 1C's.
    Ben
  • Marty913
    Marty913 Posts: 760
    Joe08867 wrote: »
    Thanks so much everyone, you confirmed my "gut feel" but that has gotten me into a lot of trouble so I figured "ask the experts".
    Joe08867, I have disconnected the dimensional tweeter on the 2's and they sound better (to me) that way. I believe it was your suggestion that got me to do that. You mentioned changing the SDA2 tweeters to match the 1C's. Don't the 1C's have the SL2000 which would be the same as my SDA2's (don't believe I mentioned that). Are either of the 1C tweeters dimensional?
    TT = Audio Technica
    Marty913 wrote: »
    The 1C's use the sl2000 for an original tweeter. They are hooked up in what is called a "Taper array". Polk did away with using a dimensional tweeter after the 2nd generation because it was found to be unnecessary and actually detracted from the overall effect.
    Furthur testing/tweaking helped them discover only the mid-bass driver(s) needed to be dimensional drivers and then only between a certain band of frequencies. For all Polks with the sl2000 tweeter a new Polk designed "silk" dome tweeter is avail (part # RD0194-1) which is much smoother and gets rid of an inherent +5dB spike at around 12.5kHz in the original sl2000. Which causes some fatigue and some nasty resonance at certain freq.
    Those are drop in replacements that can be added after you purchase the 1C's and IMO are a great upgrade and are needed if you plan to freshen up the x-overs.
  • Marty913
    Marty913 Posts: 760
    Thanks heiney9, I know the SL2000's in my SDA2's sound a little weird (disjointed, perhaps a little harsh) but assumed it was probably my x-overs needing replacement. Disconnecting the dimensional one helped. I had planned on replacing them with the 194's.
    So if I understand all this, the 1C's have the same tweeters as the SDA2's (later models like mine) but the dimensional has been dropped (so I pick up another "real" tweeter, and in addition, the x-over has been reworked to provide better control of the dimensional mid-woofer. The 1C use a single dimensional mid-woofer and 3 normal mid-woofers. Is that all correct?
    Edit: Well I may have answered some of my own stupid questions (should have checked first). From the schematics it seems the 1C's still have a dimensional tweeter but add another dimensional mid-bass (although of a different model).
    Thanks.
    TT = Audio Technica
    Marty913 wrote: »
    Thanks.
    The 1C's and any subsequents SDA speaker built after the 2nd generation does NOT have a dimensional tweeter.
    The 1C's have 2-dimensional mids and 2-stereo mids. The 2-tweeters are arranged in a taper array and both tweeters play different freq and have slightly different output from one another. The idea is to use multiple tweeters to create a single point source. It works quite well.
    IMO, when you freshen the x-overs in any speaker with the sl2000 tweeter the flaws become even more apparent and that's why I said the RD0 replacement tweeter(s) are a must if you are spending the $$$ and time on the x-overs.
    The RD0 is so much better that all my sl2000 tweeters have been replaced and it's a night and day difference.
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    1C's have two cascaded tweeters to eliminate phase shift, IIRC, 2 stereo drivers and 2 dimensional drivers. Also IIRC all the 6.5" drivers work together below 150hz to produce bass and to reinforce the fluid coupling to the passive radiator.
    I have a pair of hot rodded 2B's and stock 1C's.
    Scott
    Edit see above
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
    Check out this link:
    http://www.polksda.com/sda1creview.shtml
    For more info. It's a scanned copy of the 1986 Stereo Review-review of the 1C's. It has some good info that might help you understand a bit better what the differences are.
  • I-SIG
    I-SIG Posts: 2,243
    I'm gonna be the lone nay-sayer here and say that while you should certainly jump on the 1C's, the difference in clarity and scale from the 1C's to the original SRS's was very noticeable and for the price of the original SRS's is worth it. To go from 1C's to SRS 1.2TL's, probably not worth the price since they can go from $500 to $1000 more than the original SRS's.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • Marty913
    Marty913 Posts: 760
    heiney9 wrote: »
    Thanks you MillerLiteScott and H9 for hanging in there with my 1C ignorance. You've been extremely helpful and IF I can work the deal I will pick up the 1C's (not a done deal yet but close). I-Sig, you're certainly not being a nay-sayer to me as I have no comparison basis. I owned 2.3tl's back in the day and maybe will again when the price drops (a lot). Until then, it sounds like the 1C's will be bring me closer to the goal (sound-wise) than the SDA2's I currently have. At least it moves me in the Line-Source-Array direction.
    The link to the Stereo Review article was very, very helpful.
    TT = Audio Technica
  • genocidedeath
    genocidedeath Posts: 3
    newbie here ! any one have a pic of a sda-2 ? thx you
  • nms
    nms Posts: 671
    Dude, google is your friend.
    http://images.google.com/images?hl=en&q=polk+sda+1c&um=1&ie=UTF-8&sa=N&tab=wi
    My system
    "The world is an ever evolving clusterf*ck." --treitz3
  • genocidedeath
    google has not my type of speakers
  • nms
    nms Posts: 671
    Sorry, thought you were looking for SDA 2A. Try this.
    http://cgim.audiogon.com/i/rv/s/f/1033318612.jpg
    My system
  • Marty913
    Marty913 Posts: 760
    Here's an SDA2 with SL2000 tweeters
    TT = Audio Technica
  • Marty913
    Marty913 Posts: 760
    Marty913 wrote: »
    Just to close out the thread I started, I closed the deal on the SDA-1C's. I'm buying them from the original owner with manual & cable. Just spoke with the owner and he assures me they are "perfect". He seems to be a true Polk fan but was unaware of the Club. I will be sending him the link so hopefully we will have a new member.
    I pick them up Saturday (5 hour drive one way) so as to avoid any shipping damage as I experienced with my SDA2's. Yes, I'm excited.
    I wanted to thank all of you again. Perhaps some of you with hundreds or thousands of post don't realize (or have forgotten) what a valuable resource you are. I've been in and out of this stuff for 40 years but there is no expertise that can approach "collective expertise".
    Just wanted to say thanks to all of you that participated in this thread. It has truly helped. I plan on abusing you often.
    TT = Audio Technica
    Cool and congrats...............you will one happy camper. Perfect cond. 1 owner SDA's are hard to come by. :)
  • MillerLiteScott
    Congrat's. You will enjoy them.
    Scott
  • Mike Reeter
    Mike Reeter Posts: 4,315
    These must be the ones,congrats,you made a good buy...and they are also the Studio version.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=320191813983&ssPageName=STRK:MEWA:IT&ih=011
    Always liked the "look" of that style.
    Happy listening.
  • Joe08867
    Congrats on the purchase.
    BTW I didn't realize the original series SDA2's ever came equipped with the SL2000 tweeter. I thought they all came with the SL1000 like mine.
    So it's all bubbles no troubles matching up the sound of the 1C's to the 2's.
  • Marty913
    Marty913 Posts: 760
    Happy listening.
    Joe08867 wrote: »
    Yes Mike, those are the ones. I've been looking for a pair that was in driving distance. I think it's a fair price given the one-owner thing. He assured me they are extremely we-cared for with not a mark on them. He's driving them with Carvers so they should feel right at home when they get here. The black will match everything else but I do like the regular stained look a little better. I'm not complaining.
    Joe, I was a little surprised at the SL2000's also but from what others mentioned on here I guess it's not all that strange. The mid-bass drivers are all dated March or April of 1986. No dates on the tweets. Unfortunately they have x-over issues (dropped in shipment, I think) so that's a project after the first of the year.
    TT = Audio Technica
  • PW47
    PW47 Posts: 76
    edited May 2009
    IALREADY SEND IMAIL TO SUPORT TO FIND OUT ABOUT THE CABLE INTERCONNECTION TO SDA 2 WE ARE IN THE FORUM NOBOBY CAN GIVE LITLLE HELP ? MODEL R SDA 2 ONE ROUND PIN AND BELLOW AN HORIZONTAL . WITHOUTH THOSES CABLES SDA2 WORKS RIGHT? CAN I BUY ONE CABLE ? THANKS PWILSON:confused:
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited May 2009
    PW47
    Welcome
    Try doing a forum search on pin/blade innerconnect. You can easily make one yourself and if that does not work for you try posting in the "wanted" section in this forum.
    edited May 2009
    Considering the fact that Polk must have done a lot of R&D on the SDA series? How could 'they' have possibly missed a +5 decibel bump in their SL2000--wouldn't it have been EASY to spot something like that in their own testing and fixed it!
    I am still very puzzled as to how a silk treated RDO replacement does not radically alter the sound of an original SDA with an SL2000 tweeter. Am I just dense or am I missing something. I thought the whole idea of the SL2000 plus series was that they are, in fact, superior tweeters to silk/domes currently used by Polk? So why replace them with silk? And if the SL2000 sounds so 'bad' why did so many so equipped SDAs sell so 'well'?
    thanks,
    cnh
  • Ender
    Ender Posts: 603
    edited May 2009
    I thought they DIDn't sell well. That's why the SDA series were discontinued and the idea of trying to expand on the SDA concept was set aside.
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
