Center Speaker upgrade question
Hello all,
I read somewhere from someone with a good amount of knowledge of speakers, that it is important in an entry level system that the driver size of the front speakers should be uniform. That's why he suggested pairing my Monitor 50's with a CS1. How true is this statement?
Also, can you list from best to worst (Or less best) ways to upgrade teh center. I've heard CS2, CS10, CS20. If I'm going to upgrade, I'd like there to be a big difference. I'm not sure going from a CS1 to a CS10 is a huge difference (At least it's not a huge difference in price). Here is my current setup:
Onkyo 606
Fronts: Monitor 50's
Center: CS1
Rears: Monitor 30's
Sub: Def. Tech Prosub 800
Thanks,
Pycroft
Onkyo 606
Center: CS1
Rears: Monitor 30's
Thanks,
Pycroft
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
I would think your CS1 would be sufficient. CS2 would be an option according to other members here on different threads.
Do R50's sound different than Monitor 50's?Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
it really doesn't matter if it's entry level or audiophile hi-level...you want to timber match the LCR speakers so that there's seamless transition between three front speakers...
http://www.polkaudio.com/forums/showthread.php?t=79279&highlight=center+matchVideo: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
I wasnt talking about timber matching, I simply stated that what he has from what ive learned is already matched, an upgrade would be the CS2. With my system being basically entry level Polk equipment my Cerwin Vega center provides all of the sound its required to within my set-up. Ive tried a Polk center and it provided a different sound but in my opinion not a whole lot different to justify the cost. And im just talking about my system, not anybody elses. MOST of the equipment members have on here make mine look crappy.:oPolk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
Get the most badass center you can. When you're watching a movie the majority of the sound is coming from the center speaker so don't skimp there.
You might want to try using an amp for the center instead of trying to find a new speaker. An amp would make a much bigger difference for you. If you have a buddy you can borrow an amp from I'd suggest trying it assuming your receiver has pre-outs. -
yes, both CS1 and CS2 are matched center...I agree with you (Knucklehead) that since OP already heard CS2 and not heard any big difference, no point in going to CS2....
besides CS10 and CS20 are 2008 models for CS1 and CS2...
i didn't add these:DVideo: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
The followup question then is, what would be a timbre matched center that would be a big upgrade to the CS1. If the CS2 is similar, but not a huge reach, what would be a way to upgrade it? Would I have to upgrade all speakers, or is there something viable to match the Monitor 50's and 30's?
Thanks,
Pycroft2 Channel/HT:
Harman Kardon HK354
Sony SACD Player -
Another, possibly stupid question...I'm not sure I understand the comment about, "Using an amp for the center instead of upgrading the center speaker". Now, I see amps being sold here, and other places, all the time. To be honest, I don't get the point...I've read that some speakers need to be powered by an amp because they have a different ohm level that isn't compatible with the receiver (Not my issue). Why would I use an amp with/instead of my Onkyo receiver? What are the benefits?
Thanks,
Harman Kardon HK354
Sony SACD Player -
Thanks,
Pycroft
make sure your AVR has pre-outs.....so you can do this......http://img.photobucket.com/albums/v225/QueenB8271/MemorexAdPhoto.jpgPolk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
hey pycroft, don't worry about an amp because your onk606 doesn't have pre-outs....
I have a very similar set-up and the CS2 is a massive improvement over the CS1. And also there is no noticeable difference between the CS2 or CS20, it's just a newer version of the same line-up of speakers. The timbre and tweeter are all the same for them. Do yourself a favor and get the CS2, I got mine at newegg.com as they always have great deals on polk stuff, or go the refurbished route on the polk e-bay store.
Polk T90e's(m60)-mains
Polk CS2-center
Polk OWM3's-surrounds
Polk Micro Pro 1000-sub
PS3-blu-ray,gaming
Pioneer 43inch purevision plasma
Onkyo tx-sr606
MIT EXp 1 -
I just recently bought the CS2 and a pair of Monitor 60's and love every bit of it. Newegg is definitely the place to go I think. I used to have a Polk htib that had a tiny little center speaker and I had no clue what I was missing until I got this monster( at least compared to what I had) CS2. Its worth the little over $100 I think.
Front - Polk Audio Monitor 70
Center - Polk Audio CS2
Rear - Polk Audio TSi 100
Sub - Klipsch rw-10d
AVR - Onkyo ht-rc180
Main Amp- Parasound HCA-2003
Surround Amp- Sonance Sonamp 260
Tuner- Parasound tdq-1600
Turntable- Pro-ject Debut III USB w/upgraded platter
IPod dock - Pure i20
TV - Panasonic Viera tc-p46g10
Sony Playstation 3(250GB)
Nintendo Wii
Power Conditioner- Panamax 5100
Not in use-
Polk Audio Monitor 60
Polk Audio PSW10
Parasound p/sp-1000 -
Oh yeah....one more thing about the CS2.......it's HUGE!!!!!
Polk CS2-center
PS3-blu-ray,gaming
Onkyo tx-sr606
MIT EXp 1 -
Yeah...I found that out when it arrived in a rather large box. I was thinking that it couldn't possibly be as big as the box indicated, but I was definitely wrong on that one. I don't mind though because it has been great so far with a few movies I've watched
Nintendo Wii
Not in use-
Polk Audio PSW10
I would definetly recommend upgrading to the CS2, which I think will give your system a lot more presence during movies. I had a CS1 in my first system with Monitor 40s which was good for a small room, but you should see a big improvement with the bigger center. Plus, you can get the CS2 from Newegg for $120 shipped, and would probably get $75 on Ebay for your CS1, making your upgrade only $45. Well worth it in my opinion.
Tim2 Channel: DIY Zaph SR-71s, DIY dual 10"/240w sealed subs, Onix SP3, Onix CD-3, Thorens TD-145 (DIY moddified and restored)
HT: RS850, RS450, RSC200, SVS PB10 NSD, XPA-5, USP-1, H/K AVR354, Oppo BDP-83 -
If you can, go to a store like Frys and listen to several center channels side by side. You'll be amazed at how much more detail you hear from the movie soundtrack as you move up from the basic center channels to upgraded models.____________________________________________________________
