Flickering Display on Cambridge Audio
zombiemusic
zombiemusic Posts: 65
edited April 2009 in 2 Channel Audio
Ok people I need your knowledge once again. Less than a month ago I bought a Cambrige Audio CD player Azur 640c Version 2 from Decibel Audio in Chicago, and today I noticed that the display was dim. I tried changing the brightness, but instead of three steps it did only two, dim and off. The display flickers from time to time, just as flourescent (I know I spelled that wrong) light bulbs do as they are dieing. Now I am going to return the player because for the money and time everything should be perfect.
My question has anyone had a similar expierience with Cambrige Audio equipment? I just want to know, because I love the sonic performance it gives me. But if they are prone to technical trouble I think I will go with another brand.
Thanks again, you help to make my life sonically better!
My Gear
Phase Linear 4000 preamp
Cambridge Audio Azur 640c v.2 CD player
Dual 1219 Turntable
Two Harman Kardon Citation 16 amps
Monitor 50 speakers Bi-amped...
(dieing to upgrade to rti A9)
KLH Tremor Series sub (10 inch 125 watts)
Post edited by zombiemusic on
  • dkg999
    dkg999 Posts: 5,647
    edited April 2009
    I've had a few pieces of CA gear, and it's all been rock-solid. My dealer did notify me that there was a potential problem with the drives in the last CA DVD 540v2 I bought, and they sent it in and it was repaired very quickly. I would give Decibel a chance to make it right.
    DKG999
  • okiepolkie
    okiepolkie Posts: 2,258
    edited April 2009
    I've been a Cambridge dealer for 3 years now, and have had very few problems with the equipment I've sold and installed. Definitely try the original dealer to see if they can help.
    Tschüss
    Zach
  • zombiemusic
    edited April 2009
    Thank you, thats what I thought, from the other reviews they CA always seemed to be well thought of, I just wanted the forums view. Although, a couple of hours of being off, I tried it again, and now it apears to be working fine. Any thoughts?
    My Gear
    Dual 1219 Turntable
  • BlueFox
    BlueFox Posts: 15,250
    edited April 2009
    Don't worry. If there is a problem it will come back. Sometimes the electronic gremlins like to tease you into thinking the problem went away, but it always comes back.
  • venomclan
    venomclan Posts: 2,467
    edited April 2009
    My experience with Cambridge Audio has not been that great. I tried 4 units and they all failed in one way or antoher, some died completely. I know that Cambridge had a lot of growing pains when they moved production to China a few years ago. Perhaps they worked them out by now. Your call.
    Venom
  • okiepolkie
    edited April 2009
    venomclan wrote: »
    Venom
    I'll agree with you on the 640H ;) Other than that, I can't say I've had many problems with them.
    Tschüss
    Zach
  • venomclan
    edited April 2009
    okiepolkie wrote: »
    I give the 640H some slack since it is a complex machine. My opinion of them would be fine, if not for 2 of my 640C Ver,. 1 and SE500 failures also.
  • Emlyn
    Emlyn Posts: 4,825
    edited April 2009
    Had something similar happen with my 840C. Shortly after I bought mine (new), the characters in the display would fade in and out. The dimmer levels were not affected. I left mine in standby mode most of the time. Tried to turn it on after not using it for a few days and found it was totally dead. Toggling the power switch on the back didn't help. Sent it in to Audio Plus services (Canada) and they diagnosed a blown internal fuse. Got it back, it worked for a few days, then same thing happened again. They repaired it again and let it burn in for a week. No problems with it in the last six months.
    Would I buy another product from them? Probably not, even though I'm happy with the performance of the player. There are other alternatives.
