Bada....come to papa
    VR3 Posts: 29,549
    edited April 2009
    I see you use MIT cables -- get MIT power cables.
    Excellent drop in noise floor in my system. I highly recommend them!
  • phipiper10
    phipiper10 Posts: 961
    edited April 2009
    I use Signals MagicPower Digital Reference (below) on my pre and the Bada and their magic power for the amp.
    http://signalcable.com/digitalpowerHC.html
    Also I found the tube output the best almost immediately. A bit livelier.
    Enjoy!
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • daboyz
    daboyz Posts: 5,207
    edited April 2009
    Norm - The unit should already have had the burn-in done. That's why it takes a couple extra days to get it from them. When I purchased mine I was ready to pick it up that day but was told that they inspect and burn it in so I couldn't get it for three days.
    Funny,my tube was installed.
  • madmax
    madmax Posts: 12,434
    edited April 2009
    Manly men replace their own tubes. :)
    Here is a good video on the CD player.
    http://www.youtube.com/watch?v=l52szqMwKdE
    madmax
    Vinyl, the final frontier...
  • Norm Apter
    Norm Apter Posts: 1,036
    edited April 2009
    I have no problem handling this chore on my own, however, it would have been nice if the Owner's Manual listed the correct size star wrench needed for removing the top cover.
    I went to ACE hardware yesterday and there were a number of slightly different-sized star wrenches that all looked just about right. (At 27 lbs, I didn't want to lug the whole damn CDP there) so I made a guess and one return trip later I now have the right one. So I successfully got the cover off and changed the tube. I feel like a real man now.:)
    I noticed quite a big difference with the new tube (GE 5670) in...so I'm not quite sure what to make of this tube output vs. ss output issue. The GE 5670 sounded noticeably better over both the stock Chinese tube and SS output (with the Chinese tube), but I haven't gone back to listen to ss output with the GE 5670 in there yet.
    As for the burn in, I received two contradictory messages. I received a single-page document from them which stated (just as you did, Dave) that the unit has been tested and burned in. But the owners manual that Pac Valve prepared and included stated, "We suggest at least a 50-hour break-in period before seriously listening to the Bada HD-22." Perhaps the key here is Bada HD-22 (as opposed to Bada HD-22SE), suggesting that this is an old owner's manual and they now burn in their units whereas they used to not do so. Anyway, I e-mailed them to see what was up. Still waiting for a reply.
    Well, anyway I am really enjoying what I'm hearing. The one word or phrase that comes to mind is musical depth. In spite of the long wait, I'm very happy with my decision so far....
    Norm
    2 Ch.
    Parasound Halo A23 Amp
    Parasound Halo P3 Preamp
    Parasound Halo T3 Tuner
    Bada HD22SE tube CD Player
    Magnum Dynalab Signal Sleuth
    Magnum Dynalab ST-2 antenna
    polkaudio Lsi9s (upgraded cross-overs)
    MIT Shotgun S-3 Bi-wire Interface Speaker Cables
    MIT Shotgun S-3 Interconnects (3)
    IegO L70530 Power cords (3)
    HT
    Denon 2808ci AVR
    polkaudio RTi A5s (fronts)
    polkaudio RTi A1s (rears)
    polkaudio Csi A6 (center)
    Signal Cable Ultra Speaker Cables
    Signal Cable Analog II Interconnects
