What's a decent 150 disk or more cd changer
bevo
bevo Posts: 306
edited April 2009 in Electronics
I want to buy a 150 or more disk cd changer. I really don't want to spend much money. Anyone know of any decent ones to buy.
I actually have a 200 disk changer that's 12 years old, but I couldn't find the power cord, or remote for it. It only has rca outs, and I don't know if I should look for something with an optical out or not. That is the last cd player that I ever bought, and I don't know how it would sound. The power cord and remote would run me about 40-50$ to replace them. So I think buying a new one would be a better option.
Has technology advanced enough in cd players to warrent buying a newer one, or would my old one with rca outs work fine?
Any advice would be great.
Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra)
Post edited by bevo on
  • Gadabout
    Gadabout Posts: 1,072
    edited April 2009
    The only manufactuer that I know of that is still making the Juke Box CD players is Sony
    I have seen some used ones from Kenwood and JVC. I would suspect that not much has changed with the Juke Boxes over the years. The newer ones might have better internal DAC's, but I have never done a comparison with my existing player and a juke box. I have a friend that does have the Sony 300 CD juke box, he seems to like it. It is more about convienance than quality of sound for him. It fills the bill for him and his family.
    The newer ones do offer SACD, MP3 and other formats that you older one doesn't. Don't know if that's important to you. How is the old one running? No skipping? Still aceessing the diaks correctly? I would wonder after 12 years if it wouldn't be time for a tune -up and cleaning. My guess is you might not be able to hear much of a difference between you old one and a new one, but it might have more convienace features you would prefer.
    Wish I could be more help,
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • ben62670
    ben62670 Posts: 15,969
    edited April 2009
    I have a 200 disk Sony CDP, and a 400 disk Sony DVD/SACD/CDP. They are just fine with an outboard DAC. The analog section is lacking for most users. I would look for something with digital outs.
    Ben
    Ben
  • BlueFox
    BlueFox Posts: 15,250
    edited April 2009
    Do yourself a favor and get a digital music server. It will store thousands of CDs with instant access, random shuffle, etc. The quality of sound will be dependant on two factors; the method used to store the music on the harddrive, and the exteranl DAC.
  • bevo
    bevo Posts: 306
    edited April 2009
    BlueFox wrote: »
    What is the best format to use when putting cd's on a hardrive. I can put them on my ps3 and use it. It uses ATRAC 352 kbps. Is that a pretty high quality transfer for cd's, or can I get a better format and quality using a computer.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
  • BlueFox
    edited April 2009
    bevo wrote: »
    The best format is either uncompressed, or a form of lossless encoding. Lossless means it is compressed on the drive, but when uncompressed it is bit for bit identical to the CD data. Any form of compression, as you suggested above, will degrade the sound quality.
    Of course, another factor in this equation is the DAC being used. A music server using uncompressed, or lossless, files, coupled with a good DAC, will give the best CD players a run for the money. And, there is no way a CD player can come close to the power, versatility, and convenience of a music server.
    The drawback to a music server is you cannot put SACD files on it, but that is a minor negative.
  • rallyshark
    rallyshark Posts: 417
    edited April 2009
    I also have the sony 400 disc changer, and it has worked well for me. It also has optical, multichannel, and coax outputs, which gives you plenty of options. They can be had for just over $300 bucks new, and alot less used if you do some searching. Happy shopping!
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS3(games/media server)
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
    When rapture comes, can I have your car?
  • ahorvitz
    ahorvitz Posts: 235
    edited April 2009
    I have a Pioneer Elite DV-F07. It's a 300+1 DVD player - overkill, particularly since I use my PS3 as my video source these days. But I've found it to be a solid CD player. It's got multi, coax, and optical outs. Much like the Sonys, it can be piggybacked with another unit. Pioneer isn't making them anymore, but I've seen them on eBay.
    Main Rig
    Pioneer Elite SC-05, Rotel RMB-1075
    RT800i, CS400i, RT35i, FXi50, Klipsch RSW-12
    Pioneer Elite DV F-07, PS3, Wii
    Monster HTS 3500 MKII
    SC Analog 2, BJC Speaker Wire
    Samsung HL61A650
    2nd Rig
    Pioneer Elite VSX-56txi, Pioneer Elite DV-47a
    Cambridge Soundworks, MC150 (Center), MC100 x 4, Mirage LF-150
    Office
    Adcom GTP-400, Adcom GFA-535II, (need a quality CDP), RT55i
  • bevo
    bevo Posts: 306
    edited April 2009
    BlueFox wrote: »
    What formats will not compress the file. I use the best one my ps3 has, and it sounds a little muddy when I listen to them on it, and I've never really been one to uze a computer for anything but mp3's with my ipod. I would like to use a media server, but everything just doesn't seem to sound as good, as actually using the cd's. If I knew how to actually get the best sound out of a media server, that would definetly be the way I would go.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
  • BlueFox
    edited April 2009
    These two links provide a good overview of uncompressed and lossless compression for audio files. A Google search will provide 1000s more.
    http://en.wikipedia.org/wiki/Audio_compression_(data)
    http://en.wikipedia.org/wiki/Audio_file_format
    Are you using an external DAC with your PS3, or just the PS3 for playback? As mentioned, there are two components to having CD quality audio with a music server. The audio files must be bit for bit identical to the CD file, and the DAC must be of high quality. Scrimping on either will yield muddy, or worse, sound.
  • ViperZ
    ViperZ Posts: 2,046
    edited April 2009
    Uncompressed MP3 format is out. Read up on it...
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
