Tube question EM87
heiney9
I've got this nifty little tube hybrid integrated amp (Dared MP5, Fatman, etc) and it uses a 3rd tube EM87 as pictured. I have tried in vain to try and find out if this tube is just for show or if it is actually in the input circuit.
The reason I ask is because the one that comes with the unit is a cheapie Chinese brand and I have found some 1960's NOS EM87 tubes. If it has no effect on the sound I'm not shelling out the extra dough for Siemens or Amprex Orange Globe, etc.
Is this particular tube as it was used in the 50's and 60's as a tuning indicator typically in the signal path?
TIA for all the input.
Post edited by heiney9 on
It is just for show, kind of like the old volume meter, no impact to the sound.
-fredv- -
A show tube?? Well I suppose anything is possible but unless its on a totally seperate line it would be in the path. Any reason then you cannot remove it and see what happens?
RT1 -
Cat's Eye. Rich had one in each of his TADS iirc."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Thanks, I did come across that info while searching. Great explanation and history of the "cat's eye" tube. It really doesn't say if it's part of the signal path or not. Unless I missed it.
I suppose I could infer based on the info in that thread that's it's not in the signal path.......but I'd like to know for sure.
Thanks Ted, great suggestion I had been thinking about too. I'll pull it out tonight and see what happens.
I tried to do a comparison on my HTC iPod amp by letting it warm up good then removing the tube and turning the unit back on as quickly as possible. (gloves on ofcourse in case of heat) I didn't notice any difference in sound quality. I'm contacting Dared to see if anyone there can answer the question since I don't have the schematic for this amp.Testing
Testing
Testing -
Mine is an HTC as well. I couldn't find a schematic either and while I haven't tried to contact Dared those that have read about didn't really get a good response. But, keep me posted if you find anything out."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Wow, good memory! The TAD-60's and TAD-1000's had the 6E2 VU meter tubes in them. Paul said they could be removed from his amps without harming the circuit. They were hi-beams-on distracting in a dark room.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
