Sonic Caps for SDA SRS 1.2tl's
I am picking up my 1.2tl's tomorrow afternoon, But i would like to upgrade the tweeter's and the caps in the near future. What sonic caps do you use, and are there any scamatics for the X-OVER for these. my best bet may be to send these to Ben when i am ready to do this.
+ what do the caps run price wise?
Just wondering.
Thanks.
Larry.
Just wondering.
Thanks.
Larry.
Post edited by Toolfan66 on
The search function will answer all of your questions.Political Correctness'.........defined
President of Club Polk -
for the schematics http://www.polkaudio.com/forums/showpost.php?p=677959&postcount=5Speakers: SDA-1C (most all the goodies)
damn man going for broke eh? we will see far less post by Larry when he gets these going.
http://soniccraft.com/sonicaps.htm
I wish someone would try these in a pair of SDA's... http://www.madisound.com/manufacturers/claritycap/mr.php"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I always forget about the search function F1nut.:p Thanks. -
Thanks!!! Put that in my favs. -
Thanks Face!!
Well i have no experience with eather. This will be a first for me when the time comes. Everything i have read here on the sonicaps seems the way to go for the SDA's. this should be the last speakers i buy for some time. i really wanted the 2.3tl's, but i found these about 1 mile from my house so i did'nt want to pass these up.
Now i can save the funds for the rest of my 2 channel rig. more then likely Rotel PRE/AMP/TUNER/CDP. not sure yet, time will tell when i have a budget set.
I will more then likely save for everything else then do the upgrades on the 1.2tl's as these sound great the way they are right now. was just looking for some info.
Thanks,
Larry.
