Ever use A/V Receiver as headphone amp?
polkapolka
polkapolka Posts: 145
edited April 2009 in Electronics
Hi guys, I am hoping to hook up my audio card-Auzentech x-plosion
to my Onkyo HTR 520. Anyone have any experience with this?
Would I just connect the optical from the card to the opt. input on the amp?
Thanks for your help,
Matt
Info. on sound card:
As of June 2008, this soundcard has been replaced by X-Plosion Cinema
Auzentech will continue to provide driver updates and technical support to owners of the original X-Plosion 7.1 DTS Connect.
You may also upgrade your X-Plosion with Auzen OPAMPS.
Auzen X-Plosion 7.1 is the most anticipated "World first", high quality, Dolby® Digital Live and DTS Connect logo certified soundcard for your PC. It sounds phenomenal and is feature rich.
Experience the extreme surround-sound experience and the high-resolution digital audio while playing games, listening to music, or watching movies.
DTS Digital Surround® is the sound format found in movie theaters. The Auzen X-Plosion 7.1 turns your PC into a DTS-Connect enabled PC capable of playing full surround sound from DTS-enabled movies, music videos, music discs, and games, as well as providing surround sound from normal stereo sources.
Dolby® Digital Live, a real-time encoding technology, converts any audio signal into a Dolby® Digital bit stream for transport and playback through a home theater system. With it, your PC or game console can be hooked up to your Dolby® Digital-equipped audio/video receiver or digital speaker system via a single digital connection, ensuring the integrity of the audio signal.
The real-time interactive capabilities of DTS and DDL deliver more realistic and more fantastic contents of PC games, music and movies. Unique and luxurious design with gold plated PCB, jacks and metal bracket. Swappable dual DIP type OPAMP upgrades ultimate digital surround sound.
See also External Connections in Features and Specifications
Auzen X-Plosion MIDI Bracket
Optional X-Plosion MIDI Bracket (above)
Attach a MIDI keyboard, synthesizer or other MIDI device. Not a joystick interface.
Available separately.
[ Purchase Page ]
What is Dolby® Digital Live
Enjoy audio from your PC or game console through your home theater with Dolby® Digital Live. A real-time encoding technology, Dolby Digital Live converts any audio signal into a Dolby Digital bitstream for transport and playback through a home theater system. With it, your PC or game console can be hooked up to your Dolby Digital-equipped audio/video receiver or digital speaker system via a single digital connection, eliminating the confusion of multiple cables and ensuring the integrity of the audio signal.
Read More
What is DTS® Connect
DTS Connect is the latest thing from DTS that turns your PC into an action-packed entertainment experience that surrounds you in sound. Make your movies, music and games come alive in exciting, dynamic, multi-channel DTS Digital Surround®, the same sound format found in movie theaters. DTS Connect is a whole new way to enjoy your PC. DTS Connect makes it easy to turn your computer into the ultimate PC sound entertainment experience.
Read More: After loading a new page, please click DTS Connect™ demo on the right of the page
C-Media CMI8770 PCI chipset (8CH audio single chip with DTS® Connect and Dolby® Digital Live Real-Time Content Encoder)
8CH codec embedded PCI audio single chip
Full-duplex 8CH 24bit/96kHz DAC / 2CH 16bit/48kHz ADC
Integrated S/PDIF output supports 44.1kHz/48kHz/96kHz sample rate in XP at 16/24 bit resolution
Integrated S/PDIF output supports 44.1kHz/48kHz sample rate in VIsta at 16 bit resolution
The world's first DTS¨ Connect logo program certificated PCI audio board
DTS® Interactive : A real-time 5.1 encoder that takes any 2 or more channel and encodes it into DTS® bit stream. DTS® Interactive provides a single cable connection via S/PDIF digital audio output to a DTS® enabled surround sound system by encoding all audio into a DTS® compatible bit stream at 1.5Mbps
DTS® Neo:PC : An up mixing matrix technology that turns any 2 channel audio into 7.1 surround sound. DTS® Neo:PC, based upon DTS® Neo:6 matrix surround technology, transforms any stereo content such as MP3, WMA or CD audio, into a 7.1-channel surround sound experience
Dolby® Digital Live(DDL) Real-Time Content Encoder converts PC audio into a 5.1 channel Dolby® Digital bit stream
Swappable dual DIP type OPAMP controlled preamp circuit (4pcs output control OPAMP IC with DIY socket, 2pcs MIC input control OPAMP IC with DIY socket)
Max 2.8Vrms full swing analog output gain by unique preamp circuit / incredible powerful analog output, improve dynamic range / SNR
Proper OPAMP control circuit (+8V, -8V dual power supply circuit) for high quality audio quality, prevent audio distortion at high volume level
Package contents: Auzen X-Plosion 7.1 Audio Card / MPC to MPC(2pin-2pin) CD S/PDIF audio cable / TOSLINK fiber optic digital cable / installation CD / warranty card / owner's manual
* Swappable OPAMPs: All Auzen soundcards support swappable OPAMP sockets for OPAMP upgrades.
External Connections listed Left to Right. See photograph.
* MIC In (3.5 mm)
* AUX In (3.5 mm)
* Front, Side, Back, Cen/Sub (3.5mm)
* Coaxial Digital port
* Optical Digital port
Matt
Mitsubishi 60" HD LDP
Polk RTI-A3 L/R
Csi-a4 CC
Polk CSW 10 Sub
Pio. Elite VSX-03
Pioneer BDP-51FD Blu-Ray
Polk Fxi3s for surround.[/SIZE]
Post edited by polkapolka on
  • stuwee
    stuwee Posts: 1,508
    edited April 2009
    Wow Matt, that's a lot of info, seems like you answered your own Q! Some amps/receivers have great headphone amps built in, it really depends on the phones you're using, just like with speakers and the amp. So the ball is in your court, does this thing of which you speak work well? Headroom up in Bozeman MT has many fine amp/headphone combo's if it doesn't!
    Craig
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • Danny Tse
    Danny Tse Posts: 5,206
    edited April 2009
    I'm using a Technics SA-GX690 Dolby Pro-Logic receiver as a headphone amp to my Grado SR60 headphones. The source is a Sony DVP-NS500V SACD/CD/DVD player playing CD/SACD in 2 channel stereo mode. The combo sounds yum-yum good.
  • polkapolka
    edited April 2009
    stuwee wrote: »
    Craig
    Yeah, lol, I guess I did didn't I? Well, I guess what I should have asked is; "Do you prefer to use a separate headphone amp, or just use your AVR for your cans?"
    I will look into Headroom.
    At any rate, I am getting tons of help from everyone here on this forum. I really appreciate it all!
    Thanks,
    Matt
    Polk RTI-A3 L/R
    Csi-a4 CC
    Polk CSW 10 Sub
    Pio. Elite VSX-03
  • polkapolka
    edited April 2009
    Danny Tse wrote: »
    Great info. I was also looking at the Grados. I also like sony cd, DVD, etc. players.
    Thanks,
    Matt
    Polk RTI-A3 L/R
    Csi-a4 CC
    Polk CSW 10 Sub
    Pio. Elite VSX-03
  • stuwee
    stuwee Posts: 1,508
    edited April 2009
    Very nice folks there at Headroom, http://www.headphone.com/
    give them a call, it's always nice to talk to a real person IMHO
  • polkapolka
    edited April 2009
    stuwee wrote: »
    Alright Stuwee. I will do that when I am in a position to buy. Right now is just information gathering time.
    Matt :D
    Polk RTI-A3 L/R
    Csi-a4 CC
    Polk CSW 10 Sub
    Pio. Elite VSX-03
