RTi8 XO Mod (Complete)
curved
curved Posts: 664
edited February 2014 in DIY, Mods & Tweaks
Finished the XO mod:
Each RTi8
C1-10uF - Dayton Prec.
C2- .22uF - Sonic Cap
C3- .22uF - Sonic Cap
C4- 12uF - Dayton Prec.
C5- 25uF - Dayton Prec.
R1- 1ohm - Mills
R2- 6ohm - Mills
Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
Post edited by curved on
  • thsmith
    thsmith Posts: 6,082
    edited April 2009
    How does it sound ?
    Is this the first Rti8 mod out there ?
  • curved
    curved Posts: 664
    edited April 2009
    Started off with the resistors. Mounted them underneath - finished it off with a dab of super glue to keep it tight to the board.
    Pre - Nak CA-5
    BR - LG BD390
  • curved
    curved Posts: 664
    edited April 2009
    Then I went to and did both .22uF Sonic Caps. I will say that the Sonic Caps are a little easier to work with than the Daytons.
    Pre - Nak CA-5
    BR - LG BD390
  • curved
    curved Posts: 664
    edited April 2009
    Then worked into the Daytons. I chose to do them on the sides because the 25uF Dayton was too big in diameter to fit on the board. I would have never been able to get it back in the cabinet.
    Not the cleanest but definetly solid. I'm not worried about it rattling around loose;)
    Pre - Nak CA-5
    BR - LG BD390
  • curved
    curved Posts: 664
    edited April 2009
    thsmith wrote: »
    How does it sound ?
    It's a no-brainer difference right off the bat. The biggest difference that I notice is sound stage and instrument separation. My wife even noticed it (which is quite amazing to me:eek:). Things don't blend together as much. If you are able to do this mod, I would highly suggest it. Although I think I would have done the inductors next time. ;)
    Pre - Nak CA-5
    BR - LG BD390
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2009
    I'm sending mine over:)
  • curved
    curved Posts: 664
    edited April 2009
    leroyjr1 wrote: »
    Which ones?;) Let me know if you want to do yours. I'm more the willing to give you a hand. I am getting low on flux though.:p
    Pre - Nak CA-5
    BR - LG BD390
  • thsmith
    edited April 2009
    Nice job, I went from RTi8s to SDA-1Cs.
    Did the mod make the highs warmer ? As I remember they seemed to be on the bright side.
  • curved
    curved Posts: 664
    edited April 2009
    thsmith wrote: »
    They are still a bit bright but VERY detailed. I'm pretty sure they will warm up after they burn in a bit. I'll keep you all updated once everything is fully burned in.
    Pre - Nak CA-5
    BR - LG BD390
  • ben62670
    ben62670 Posts: 15,969
    edited April 2009
    I am guessing that you are a pioneer in the RTi line up XO upgrades.
    Congrats, and thanks:)
    Ben
    Ben
  • Face
    Face Posts: 14,340
    edited April 2009
    If you do decide to swap inductors, I would leave the one in the HF circuit alone, it's already an air core. I would replace LF inductor with an air core unit of similar DCR.
    Also, if you're looking for a little more warmth, you could either add a little resistance to the HF circuit or use a LF inductor with a lower DCR. But I would wait till the components start to break in before re-engineering anything.
    Nice job!
  • curved
    curved Posts: 664
    edited April 2009
    ben62670 wrote: »
    Ben
    Thanks!! I can pretty much do the 8's in my sleep now ;)
    Face wrote: »
    Nice job!
    What brands have you worked with?
    I'm going to let it burn in and see how I like it. I may be asking a few of you guys some questions then ;)
    Appreciate the feedback!!
    Pre - Nak CA-5
    BR - LG BD390
  • nikolas812
    nikolas812 Posts: 2,915
    edited April 2009
    Congrats.
    I heard the exact same things with my M5 upgrade. Soundstage and better separation.
    Let them burn in. It will warm up...
    Nick
  • Systems
    Systems Posts: 14,873
    edited April 2009
    curved wrote: »
    I will throw my $.02 and say that Solen perfect lays are a good choice for air cores.I have used them in many projects. http://www.solen.ca/pub/cms_nf_catalogue_niveau3.php?q=Jm5pdmVhdTE9MSZuaXZlYXUyPTQmc2VjdGlvbj0yJnNvdXNfc2VjdGlvbj00JmZ0PW5m
    Btw it's hard to tell for certain from the pic, but on the big inductor is the center of the plastic bobbin hollow or does it have a piece of metal in it?It appears to be hollow which would make it an air core.
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    edited April 2009
    I agree with Fred, Solen are a good value. Madisound's house brand, Jantzen, and Erse are decent values as well. I usually choose the brand based on the DCR needed. Goertz are nice too, but they're bulky and can be pricey.
  • quadzilla
    quadzilla Posts: 1,543
    edited April 2009
    Asked this in another thread, but I'll ask here as well; is there a specific reason to choose one type of cap over another for the different parts of the xover? And if so, where could I find some more information on that? I'm actually interested in modding a couple of sets of RTis (RTi 12 and 70) as well as rebuilding the xovers in a pair of LS50s if they don't sell soon. And hell, probably do the center and surrounds while I'm at it. I'm less worried about cost than if it'll make a noticeable improvement in fidelity.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • curved
    curved Posts: 664
    edited April 2009
    quadzilla wrote: »
    IMO, you mod to match your system. So if you have $100 speakers, you shouldn't spend $300 on caps. Keep it all relative to the rest of your system. Good place to look is http://soniccraft.com/
    I used Sonic Caps for the highs - I heard a lot of good things about them for the $.
    Pre - Nak CA-5
    BR - LG BD390
  • quadzilla
    edited April 2009
    curved wrote: »
    Thanks. But what I'm really looking for is not a place to get caps, but information on choosing the right cap for a given section of the xover, so I'm wanting to know where is it best to use a electrolytic cap vs. a film cap, etc.
    Arm: Rega 300
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited April 2009
    You will want to use film caps.
    Which speakers are you thinking of rebuilding?
  • ben62670
    edited April 2009
    Well I am not well off by any means so I did a shootout of some cheaper caps.
    http://www.polkaudio.com/forums/showthread.php?t=61727
    Others have added to that thread with some good info. I am not dismissing any opinions, but Face has tried different caps with the same setups to get his hands on listening impressions.
    Ben
  • pablo_rodz
    pablo_rodz Posts: 331
    edited April 2009
    I wish I would know more about this... I would mod my RTi 10's in a heart beat!!!
    I mod my cars, but I don't have the electronic knowlege to choose whatever I need, and then solder it in the "right" place. I'm afraid I would fry something....
    Anyone in the Houston area care to teach me?
    HT:
    Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
    Living Room:
    Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7
  • Willow
    Willow Posts: 11,232
    edited April 2009
    How much would it cost and where do I sign up?
  • quadzilla
    edited April 2009
    NJPOLKER wrote: »
    For both high and low frequency sides?
    Pretty much all of them in my signature, plus some LS50s and LS FX that I have. Maybe also the CSi400 and CSi3 that I picked up recently. Even though I'll probably be selling all the latter, if upgrading makes them sound better, then I'll call it a present for who ever I sell 'em to. I just like stuff to sound as good as it possibly can, and I like to tinker. I think I'm doomed.
    Arm: Rega 300
  • danz1906
    danz1906 Posts: 5,144
    edited April 2009
    Nice Mod
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • curved
    curved Posts: 664
    edited April 2009
    quadzilla wrote: »
    For the 12's I would use the Sonicaps lows/mids and Mundorf or Dynamicap for the highs. I think you will be very surprised. ;)
    danz1906 wrote: »
    Nice Mod
    Thanks!!
    Pre - Nak CA-5
    BR - LG BD390
  • Face
    Face Posts: 14,340
    edited April 2009
    quadzilla wrote: »
    Yes, for highs and lows.
  • quadzilla
    edited April 2009
    curved wrote: »
    Face wrote: »
    Thanks, I'll give it a shot.
    Arm: Rega 300
  • quadzilla
    edited April 2009
    Of the Mundorfs, between the MCap, MCap ZN and MCap Supreme (I'm the sure the silver and gold will be cost prohibitive), is there a recommendation?
    Arm: Rega 300
  • Face
    Face Posts: 14,340
    edited April 2009
    MCaps or dayton would be fine for the woofer/LF. For the tweeter, look into either Sonic Caps, Claritycap SA, Dayton, or Mundorf Supremes, etc... You should start your own thread. ;)
  • quadzilla
    edited April 2009
    Face wrote: »
    Yeah, should've known this wasn't a "do this, be happy" kind of question.
    Arm: Rega 300
