LSi f/x
bdtae5656
bdtae5656 Posts: 235
edited April 2009 in Speakers
Can these speakers be powered at 8ohms by my AVR for the time being until I can buy another amp??? Or would the LSI 7's be best for my setup.
TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables
Post edited by bdtae5656 on
  • zx_toth
    zx_toth Posts: 417
    edited April 2009
    The LSi FX are also a 4 ohm speaker requiring some amplification beyond which a AVR rated at 8 ohms can safely drive. My understanding is that you would risk damaging the speakers if you under powered it with insufficient power. If you are really into having surrounds at this point it may be better to use some old 8 ohm speakers kicking around to do surround duty until you have a sufficient amplifier for the LSiFXs.
    It is most important to have your front stage speakers match. Having surrounds match is ideal but is less important than the front stage. This may be a good temp. solution. Do you have any speakers from an older Home Theater rig or does a friend have some 8 ohm speakers he can loan for a few months that are otherwise sitting in his closet??
    Z
  • bdtae5656
    edited April 2009
    zx_toth wrote: »
    Z
    Yeah I figured it would be a bad idea...I still wanted to ask the polk audio world! My understanding is that the rears are a little more understanding than the mains when powering them at there highs level. What about the LSI 7's...there's some post that the 7's dont drop below 6 ohms.
    No rears...I might have to go yard sale shopping!
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • zx_toth
    zx_toth Posts: 417
    edited April 2009
    Yard sale shopping would do it :p
    How long before you will have saved up for a new/used amp? If its bareable <sp?> you can hang in there with your 3.1 system until you have sufficient coin to buy the amp and LSi surrounds. Ive had to do it in this step wise fashion, replacing my RM center with an LSiC and a sufficient amp. Im about to get some surrounds but have been without 5.1 for over a year.
    If it is TOOOOO LOOOOOONG before (more than 6 months for example) and you cant wait to have surround sound again you may be able to pick something up an 8 ohm surround speaker pair used on Club Polk flea market, Craigs list and if you get a great deal you can re-sell it for the same price later on ... all options.
    Good luck.
    Z
  • bdtae5656
    edited April 2009
    xcapri79 wrote: »
    I would answer yes as long as you don't push it to really load volumes. The Harmon Kardon receivers are actually pretty good. From my experience with them, they typically underrate their power output.
    It is common to use the LSiFX for the side surrounds and the LSi7's for rear surrounds. It is true that the LSi7's are not as difficult to drive.
    I would point out that with your XPA3, you will have already removed the significant burden of powering the center and fronts from the AVR.
    For surround applications, you will set your speakers to small with a 80Hz cutoff. The LSi's are hard to drive below 80Hz, so as long as you stay away from that in your application you should be ok.
    To note, I ran my LSi's on my Pioneer VSX-1018AH for some time on my master bedroom system where loud volumes were never used. I eventually added a XPA3 amp for the fronts and moved my LPA1 from the main room to the master bedroom set up for the surrounds. I just finished adding a Polk 42" surroundbar powered off the AVR for the times I don't want to run my amps but still want great sound.
    Will the AVR send out more watts to the Fx's since there the only speakers hooked up to the AVR
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • bdtae5656
    edited April 2009
    Should my LSIC be turned to large or 80hZ???
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
    nooshinjohn Posts: 26,000
    edited April 2009
    I got a set of b-2 klipsch speakers with original box you can get for 130 plus shipping...
  • zx_toth
    zx_toth Posts: 417
    edited April 2009
    bdtae5656 wrote: »
    Good question .... I would be interested in hearing what some other owners have to say about this. I have my LSiC set to 'small' and it sounds fantastic but honestly I have never experimented with putting it to 'Large'. Anyone have any opinions on this?
    Z
  • Bernal
    Bernal Posts: 991
    edited April 2009
    zx_toth wrote: »
    Z
    Hi,
    I have configured my LSi Series as large. Video: The sound is excellent. In small stereo.;)
    1) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
    2) HITACHI P55T501. 55" HD1080 Plasma HDTV
    3) DENON DVD-1740: Progressive Scan DVD Video/CD Player
    4) DENON DVD-2500BTCI: Blu-ray Disc™ DVD/CD Digital Player/Transport
    5) POLKAUDIO LSiC (Center speaker)
    6) POLKAUDIO LSi15 LEFT (Front speaker)
    7) POLKAUDIO LSi15 RIGHT (Front speaker)
    8) POLKAUDIO LSif/x LEFT (Surround speaker)
    9) POLKAUDIO LSif/x RIGHT (Surround speaker)
    10) SONY SA-WP16 ( Sub Woofer 2X200W)
