Brown-Burr/Texas Instruments USB DAC
zingo
I just received a Brown-Burr/Texas Instruments USB DAC from Fred (GV#27). It looks like a fun little unit that was designed for headphones, and I plan on converting it to RCA. I'll be updating it as I make progress.
Post edited by zingo on
Glad it made it there safely.I see someone is selling a similar item on Ebay.Im betting it also uses the PCM2704.http://cgi.ebay.ca/HOTAUDIO-MARK-IV-USB-HEADPHONE-AMP-AMPLIFIER_W0QQitemZ280324337357QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item280324337357&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318Testing
Testing
Testing -
In case you're interested... loooong thread about hotaudio and how awesome he is: http://www.head-fi.org/forums/f5/hotaudio40-s-amps-242880/SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality -
Thanks for posting that link ,I just skimmed through for now but it looks interesting.It appears like he uses the near identical PCM2705 and adds an opamp to buffer the output.I think this is exactly what Zingo is looking at doing.In case you're interested... loooong thread about hotaudio and how awesome he is: http://www.head-fi.org/forums/f5/hotaudio40-s-amps-242880/Testing
Testing
Testing -
Thanks again for the board Fred! Since I'm not much of a headphones guy, I installed a pair of RCA outs for the board. It works well and I was suprised but the sound. Maybe that's because I am currrently using an AMC 8 DAC... I was thinking it would be fun to couple this to a little chip amp and house it all in one chassis. It would be great for a computer as it would be small, make decent power, and only have USB in, power in for the chip amp, and speaker outs.
Add in a pair of speakers like the little Vifa recession busters kit from Madisound,and you would have the making's of a good PC rig.... I was thinking it would be fun to couple this to a little chip amp and house it all in one chassis. It would be great for a computer as it would be small, make decent power, and only have USB in, power in for the chip amp, and speaker outs.Testing
Testing
Testing -
Fred is awesome. Super guy.engtaz
Any suggestions or sources for a good chip amp and power supply?
Here http://www.chipamp.com/ and here http://www.audiosector.com/
Or you can get the Chips directly from Digi Key for $5 ish each and just use point to point wiring.
I believe PE also sells the LM3875/3886 chips and have some suitable toroidal xformers.Testing
Testing
Testing -
My newest consideration is to integrate the DAC into my K16LS amp. It would have the ability to accept RCA or USB input depending on what was wanted/needed. I'm still working on the details...
I just finished installing the board into my K16LS and it now allows the amp to accept unbalanced cables or USB. The sound is great and as good as my AMC DAC 8. Plus, the internal DAC works pretty well for this amp because it has pre section with a pot that I already bypassed. So using the USB in, the signal goes USB>DAC>Pre>Amp, all with the volume being controlled with the computer since this is my PC rig. I'll post pictures later after a few more tweaks.
A USB dac /tube amp,now thats cool.Testing
Testing
Testing -
Well thanks! I was inspired by the Peachtree Audio Decco. They claim that a DAC followed by a tube pre section really tames down the "digital" sound. I looked at my amp below my desk and said, "I can do one better."
I was listening to my new "super amp" last night when I heard a weird pop or such noise come out of the speakers and the music stopped. I did the simple checks and everything seemed to be fine, except that the computer no longer saw the USB DAC, or any other USB devices for that matter. I restarted the computer and upon loading Windows, received a USB Overvoltage error and it would not allow start-up with the DAC plugged in. I unplugged the DAC, started the computer fine, tested the amp and it works great. I have scoured the DAC board and find no burnt components or anything the looks suspicious. The only thing I can think of is that I never grounded the USB terminal to the board after I moved it, but I'm not sure if that would cause an overvoltage anyway. Has anyone see this problem before or know anything about "USB overvoltage"?
Is the DAC being powered via the USB port or did you give it a separate supply?Testing
Testing
Testing -
Testing
Testing
Testing -
Not sure if it will work but there are 2 or 3 jumpers marked self and bus.Place the jumpers in the self position then you can use a 9volt battery to power the unit.Ofcourse be sure to hook it up with the correct polarity.Testing
Testing
Testing -
I played around with the jumpers and got the unit so that when I plug in the USB, the unit powers up and registers with the computer, than a second later shuts off and disengages all USB ports on the computer. Unplug it and all the USB ports work instantly.
Something on the DAC board must have failed.Testing
Testing
Testing -
Try this.If you are operating it from the battery (with USB disconected)you can check the voltage at the self pins with your multimeter.You should get 3.3 volts.Testing
Testing
Testing -
I'll have to find a 9v battery and I'll look over the board again.
As I just told Fred, I got the unit working again (I think two of the USB wires were touching) and I will try to post pictures of the completed unit tonight; DAC installed in amplifier.
Very cool.I bet the tubes add some body to neutered MP3 files.What are you using for speakers?Testing
Testing
Testing -
Don't worry, there aren't any MP3s running through that amp.
I am currently powering my CRS+ and they sound really good except for being a little bass shy. This amp also sound fantastic with my old Monitor 5Jrs.
