Am I blind? Where is the store?
jrgoswick
jrgoswick Posts: 159
edited April 2009 in DIY, Mods & Tweaks
Either I'm loosing my mind, OR there is no place on the website to order parts. Do they only order over the phone? Why is there not a place to do this here? I need poly switches and RDO's for my M12's.
Onkyo TX-SR705 AVR
Onkyo M-501-Given to my father.
Onkyo DX-C730 CD Changer
Onkyo DV-BD507 Blu Ray player
Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
Polk Monitor 12's with RDO's and XO's
Polk CS300 Center
Polk Monitor Series 4 rears
EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek:
Post edited by jrgoswick on
  • Face
    Face Posts: 14,340
    edited April 2009
    You need to call them during normal business hours.
  • zarrdoss
    zarrdoss Posts: 2,562
    edited April 2009
    dont know which one exactly you need but here are some options from parts express, would any of these work? any of you guru's know?
    http://www.parts-express.com/wizards/searchResults.cfm?FTR=&search_type=main&WebPage_ID=3&searchFilter=polyswitches&x=24&y=5
    treitz3 Posts: 19,969
    edited April 2009
  • jrgoswick
    edited April 2009
    zarrdoss wrote: »
    I'll get ones from Polk when I get some coin(and poly switches). These are the ones I got from you. And they sounded GREAT until that nasty MP3(Learning to Fly by PF) killed one of them.
    Onkyo TX-SR705 AVR
    Polk CS300 Center
  • zarrdoss
    edited April 2009
    well crap, Id go with the new rdo's and put a poly's for sure. I need to find what poly will work for mine and replace it in the 2.3tl's
    edited April 2009
    Where were your tone controls set at when the tweeters failed?
  • jrgoswick
    edited April 2009
    Flat(0dB), if you could call it that. I'm using an OLD Sansui 5000A. I recapped the power supply a few years back and added a few uF to it to stiffen up the low end. The volume was at about 25 to 30%! I've had this happen before in a pair of M10's at low volume, so I wasn't really surprised, just pissed off.
    Onkyo TX-SR705 AVR
    Polk CS300 Center
  • jrgoswick
    edited April 2009
    zarrdoss wrote: »
    I think/thought the schematics and parts lists are/were floating around here somewhere. Whomever did that should create a sub catagory for that info and set it up with read only attributes(unless you're the owner, for future editing).
    Onkyo TX-SR705 AVR
    Polk CS300 Center
