audio illiterate
j_tre287
j_tre287 Posts: 2
hey guys, i hate to admit it but i'm a newby at this sort of thing, so i'll get right to my dilemma;
i'm attempting to hook up a couple un-powered sub woofers to my car audio system which doesn't have sub outputs of it's own. is it possible to hook these up without use of an amp...or is that going to be an absolute necessity? (i would prefer to not have an amp because, well, while it is a car stereo system, i'm not putting it in my car. long story, but an amp would be difficult to mount and bulky in this situation, but if i need one, i could probably make it work)
Post edited by j_tre287 on
  • lightman1
    lightman1 Posts: 10,796
    edited April 2009
  • snow
    snow Posts: 4,358
    edited April 2009
    Just curious here but exactly how do you plan on powering these "Un Powered" subs without an amp? never mind the whole car audio not going into a car thing.
    REGARDS SNOW
  • george daniel
    george daniel Posts: 12,096
    edited April 2009
    Eh,, you might wanna' put those subs back in the box and think about what it is that you are wanting to accomplish,,anyway,, good luck,,don't blow anything up.
  • average_guy
    average_guy Posts: 236
    edited April 2009
    j_tre287 wrote: »
    Could you post some pics? :rolleyes:
    treitz3 Posts: 20,017
    edited April 2009
    If I'm reading you right, just hook them up to the amp you have. It'll sound like **** and I wouldn't turn it up that loud but it'll work.
  • j_tre287
    j_tre287 Posts: 2
    edited April 2009
    well... while reading a little about subwoofer installation, i read that some self-powered woofers can extract the bass from the sound system themselves. i was wondering if there is some modification or adapter that could do the same thing for unpowered woofers; if some way to extract the bass from my system and send it to the subs without having to use an amp.
  • lightman1
    edited April 2009
    edited April 2009
    Try telling us what you have and what you want to accomplish. That will help us to help you.
  • lightman1
    edited April 2009
    Allright. Try a passive 12db X-over.
  • BlueFox
    BlueFox Posts: 15,251
    edited April 2009
    I have a home audio passive 15" woofer in my den. It makes a great end table.
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited April 2009
    If I understand what you are trying to do correctly, hooking up the sub should work. Sound quality would be suspect, but this is a woofer with limited frequency response, so it might work out OK.....
    The Lightman suggests a crossover. Definitely helpful ... basically you are creating a two or three way speaker (you didn't say what else the amp is hooked to and how).
    Concerning either of the above, a thing to be very careful about is the resulting impedance, as an effective parallel wiring will cut the assembled speaker rig impedance ... could be bad for the amp if it goes too low.
  • Hillbilly61
    edited April 2009
    BlueFox wrote: »
    Truely passive, huh? ;)
  • BlueFox
    edited April 2009
    Ka-ching. We have a winner.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited April 2009
    I think I got a headache trying to figure this one out.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • lightman1
    edited April 2009
    Passive..active whatever. Apparently this OP's question was not clearly defined.
    And he only has 2 posts.
    Don't feed the fishing.
  • McLoki
    McLoki Posts: 5,231
    edited April 2009
    Strictly a guess - but could you be confusing a subwoofer (in this case a passive one) with a passive radiator?
    They are physically different things and no, you cannot use a subwoofer as a passive radiator.
    As others have said - tell us what you have and what you are trying to accomplish and we will see what we can do with it...
    Michael
