I'm clipping.
Ricardo
Ricardo Posts: 10,636
edited May 2009 in Electronics
Yup; My Marsh A400s' led is blinking with the MMG's at high volume. Those panels do dig low.
Oh well, I don't usually listen at those levels (measured at 96 db), so not that big of an issue.
But for some reason I am regretting having sold the Belles.
SOPA
Post edited by Ricardo on
«134
  • ben62670
    ben62670 Posts: 15,969
    edited April 2009
    My Adcom's blink a little when I go nuts. The indicators just show when the distortion is getting up there. If it is pretty solid on the lights then you may be clipping, but I have never gone that far. I see a few blinks and I do not go any higher. Are the Marsh amps the same as far as the LEDs?
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited April 2009
    That's the problems with those type of speakers and ribbon speakers, they can drop pretty low. No worries thou, Ricardo knows what to do. (Buy different speakers)
    LOL
    I'm sorry I could not resist.
    engtaz
  • Ricardo
    edited April 2009
    I would assume the blinking means it is getting up there, but I have no literature on that.
    When I had the 1.2's and the GFA-555 those lights loved to blink.
    Different speakers? Yes, probably a pair of Maggies 1.6 :eek:
    SOPA
  • ben62670
    edited April 2009
    Ricardo wrote: »
    LOL running the big SDA's and the sonosub I had a mini light show going on with all my Adcom's blinking to the beat:) 565's, 585, 555, and the 7500 :eek: :eek:
    Ben
  • george daniel
    george daniel Posts: 12,096
    edited April 2009
    Ricardo wrote: »
    Hmmmmmmmmmmmmmm, ;)
    heiney9 Posts: 25,431
    edited April 2009
    A couple of these Mono's...............problem solved.
    http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1242590404&/Pass-Labs-X-600.5-mint-conditi
    :D:D:D:D:D:D
    edited April 2009
    Ricardo wrote: »
    Blinking hard or steady is about 3% distortion. Subtle blinking is about 1% distortion. With Adcom the lights flicker quite a bit before any damage can be done..........generally speaking.
  • dkg999
    dkg999 Posts: 5,647
    edited April 2009
    Is that an electical consumption guage on that amp ;)
    DKG999
  • megasat16
    megasat16 Posts: 3,521
    edited April 2009
    I've never clipped my amps driving a pair of Plats. But you should Try These!
    http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1244053089
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • PSOVLSK
    PSOVLSK Posts: 5,379
    edited April 2009
    My system is so lo-fi:p:o
    SCompRacer Posts: 9,111
    edited April 2009
    No problem, cut the lead to the LED.:D
  • agfrost
    agfrost Posts: 2,467
    edited April 2009
    SCompRacer wrote: »
    Ha! That was the local auto repair shop's solution to my brother's check engine light 10 years ago. Needless to say I don't throw them any business.
    Jay
    Jay
  • polkie4life
    polkie4life Posts: 231
    edited April 2009
    Ricardo wrote: »
    Is the power cord or plug getting warm at all?
    In terms of audio, i truly feel sorry for the visually impaired. How can they know what they like if they cant read google?
    http://www.polkaudio.com/forums/showcase/view.php?userid=86838
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited April 2009
    Ricardo
    As I remember you had your Belles 350a upgraded to reference by David Belles, correct?
    I had a conversation with David a few weeks ago and he told me it's now $1,500 to do the upgrade. Not a direction I will go at $1,500. thats for sure. I will say the 350a is a really nice amp. At every level of volume the sound quality is awesome. I've never enjoyed listening at lower volume levels till now. Oh well good luck.
  • tom t
    tom t Posts: 543
    edited April 2009
    mmg's, those are the smaller mag's,correct? very suprized the 400 would go into clipping. i know you probably would consider it a down grade, but a parasound 3500 would blow the mmg back to the factory if you try cranking the thing up. and to tell the truth,it wouldent sound bad at all.
  • BlueFox
    BlueFox Posts: 15,251
    edited April 2009
    Ricardo wrote: »
    Not familiar with the equipment, and if a lot of bass is present it can take a good amount of power, but 96db, while certainly loud, is not that high.
    More to the point, does the amp do a good job of preventing damage to either itself or the speakers? I suppose it is from the lackadaisical tone of your post.
  • ND13
    ND13 Posts: 7,601
    edited April 2009
    I've witnessed Ricardo's predicament. I'm surprised that the SPLs were that high. Seemed like the amp "blinked" quicker than that, but it could have been the disc I was demoing.
    Still sounded sweet in conjunction with the MicroPro sub.
    Ricardo, did you ever cross the MMGs? I wonder if they were crossed at 100-120hz if that'd help the dips??
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • danz1906
    danz1906 Posts: 5,144
    edited April 2009
    Is the Marsh-400 considered a high current Amp?
    Its has enough power to drive your speakers.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2009
    your word(s) of the day are impedance curves, you may be suprised at what you find, check it out.
    btw--Tubes Rule.
    RT1--Hint.........How many ampres can be delivered into say a 50K load?
  • Ricardo
    edited April 2009
    No more clipping in my future:
    :D:D:D
    SOPA
    edited April 2009
    Good job Ricardo.......you finally got a 'real' amp :p;) . You are going to **** your flat hat when you get this up and running!
    The difference between the Aleph 30 and the Marsh A200s I used for awhile was very apparent. I assume the similar for your situation and may even be greater. Plus, if it just doesn't play well or you don't like it you'll get all your money back if you have to flip it.
    Looking forward to an honest review from you. Congrats!!!
  • tom t
    tom t Posts: 543
    edited April 2009
    very nice amp you have there. i was thinking of getting one myself. good luck with it
  • Face
    Face Posts: 14,340
    edited April 2009
    I'm jealous, congrats!
  • megasat16
    edited April 2009
    Nice Amp! Congrats!
  • Ern Dog
    Ern Dog Posts: 2,237
    edited April 2009
    Way to do it right!
    I've been pondering about getting one too. Yes, we are going to need a review soon.
  • ND13
    ND13 Posts: 7,601
    edited April 2009
    Just send the "OLD AMP" my way.:p
  • Systems
    Systems Posts: 14,873
    edited April 2009
    Congrats on a nice little amp.
    My understanding is that while the impedance of some Maggies can be on the low side ,the impedance does not vary with frequency as much as with a system using regular drivers like say the LSi9.
    RT1-- Hint .......how many ampers can be delivered into say a 50k load?
    Im betting a few miliamps would suffice.
    Testing
    Testing
    Testing
  • megasat16
    edited April 2009
    GV#27 wrote: »
    Unless RT1 uses a different Ohm's Law for tube amps and 50K ohms load. :D
  • Face
    Face Posts: 14,340
    edited April 2009
    MMG impedance curve.
  • ben62670
    edited April 2009
    Ricardo wrote: »
    :D:D:D
    I need a tissue:o
    Ben
