Harmony 880
polktiger
polktiger Posts: 556
edited April 2009 in Electronics
I see New Egg has this remote (reconditioned) for about $100.
I have resisted buying something like this given past experience with programmable remotes (however, that experience goes back about 10 years or more). Essentially why I have resisted buying one was that I found with those older remotes you still had to keep the "real" remote for that devise to access the special settings menues, calibration options, etc.
For those that use a Harmony remote, will it actuall handle all those commands for the original device?
Post edited by polktiger on
  • Conradicles
    Conradicles Posts: 6,339
    edited April 2009
    They do it all. Buy it. Trust me. They are fantastic.
    Never need to touch any of my remotes except the one for the PS3 and only because it is Bluetooth and not IR. But a fix is on the way for that soon...
  • Blownrx7
    Blownrx7 Posts: 137
    edited April 2009
    polktiger wrote: »
    For those that use a Harmony remote, will it actually handle all those commands for the original device?
    The answer is a qualified yes.
    I have the 880 and I have programmed in my system. A usual, the programming is NOT always an exact duplicate of the original remote.
    BUT, with some work on your part, you can make it seem identical. It will require using the original remote so the 880 can LEARN the commands.
    It's not very hard at all (but it can be time-consuming) and the 880 is especially nice because you get out of the habit of feeding batteries to your remote control.
    I actually had the 659 before it died and preferred that one for the button layout (the 880 button layout is inferior imho) BUT the 659 is NOT rechargeable and I was tired of picking up the unit and finding my rechargeable batteries needed charging again...
    BTW, if you wait long enough the 880 occasionally comes up for ~$100 NEW
    hth...
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2009
    880 isnt bad but if you search around you can find the Harmony One for not much more. I had the 880 and though its a good remote, the One is better. If the you can spend the extra coin 40-50 bucks to be exact, opt for the One.
  • bobman1235
    bobman1235 Posts: 10,822
    edited April 2009
    I have the 880, haven't had to touch my original remotes since I got it. I had the same hesitation as you, but it's really a great device.
  • Lowell_M
    Lowell_M Posts: 1,660
    edited April 2009
    +1 to all of the positive responses. I use my 880 exclusively in my HT and even have it programmed for the NYKO PS3 infra red remote dongle.
    I have a 659 that is older and not nearly as easy to set up. Harmony has made good strides in recent years.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • tryrrthg
    tryrrthg Posts: 1,896
    edited April 2009
    this will help a bit...
    from techbargains.com
    Logitech Harmony 880 Advanced Universal Remote (Refurb) $89.99 w/ Coupon, Free Shipping, Apr. 7 7 AM
    Dell Home has the Refurbished Logitech Harmony 880 Advanced Universal Remote for a low $89.99 after Coupon Code: EMCLRLV32 (Exp 4/13). Free Shipping. Tax in most.
    The Harmony remotes allow you to control multiple electronics from a single remote via infrared. It is very easy to configure using the included web-based setup.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited April 2009
    +1 again for the 880, I love mine and I bought it back when it cost me almost $200. It is a great remote that can do just about anything (except PS3, but as stated there is a fix in work for that) Software is pretty user friendly in setting it up, and setting up Macros for multiple function commands IE watching a dvd or listening to the radio etc. Def. pick it up if you have the oppertunity. Have heard good things about the Harmony One, but have no experience with it.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • kuntasensei
    kuntasensei Posts: 3,263
    edited April 2009
    +1 for the 880. I'm running a semi-complicated setup (43" RPTV and projector in same room, signal fed to both with a component matrix switcher) and was surprised that it had every freakin' code I could ever want and was super easy to set up. Since you can scroll through the menus on the LCD screen for all the in-depth alternate remote commands you normally can't do on programmable remotes, you will seriously never need to pull your original remotes out again.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • SuperG
    SuperG Posts: 34
    edited April 2009
    Well, I purchased the Harmony 720 a few years ago and I absolutely love it. :) (Not sure if its comparable to the 880). My first thought was; I cant believe I just spent $200 on a fringin' remote:eek:...but I soon realised it was worth every penny.
    You can customize this remote the way you want it. Yes, you might need the original remotes to set it up properly. But once done, you might as well remove the batteries on the original remotes...that's how often you will need to use them afterwards.
  • raidersrule76
    raidersrule76 Posts: 471
    edited April 2009
    Off subject a little bit but I have a harmony 1000 and I love it. I bought it for around 200 and I think that it was worth every penny. I also thought what the hell am i doing spending this kind of coin on a remote, and yes it does everything that the origanal remotes did I haven't had to look at my remotes since and I love the fact that I dont have to hunt for batteries anymore.
    Sig to be updated after dealing with the insurance company:(:(:(
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited April 2009
    SuperG wrote: »
    I've got an 880 refurb on order from Amazon for $80 + tax, but was really torn between it and the 720 (refurb can be had from Tigerdirect for around $60).
    The two are close functionality wise, with the 880 allowing for a few more groups. The 880 appears to have a slightly bigger screen too. Research showed some 880s as having issues with setting correctly in the charging cradle. Frankly, I could not find any complaints about the 720.
    What did it for me was the 880 has backlit buttons and the 720 doesn't. It's a small thing, but can be a long term irritant in a dark room.
    About either, don't bother with eBay. The refurb bids are going for and sometimes exceeding the same as from large retrailers. Also, I've noticed a couple of suspicous looking vendors from China peddling them there.
  • fast1
    fast1 Posts: 27
    edited April 2009
  • olilugo
    olilugo Posts: 405
    edited April 2009
    refurb = refurbished. It means either it was returned because the buyer changed its mind and the manufacturer decided to run full diagnostics on it anyway but it can not be repackage as new. or it was sent back because of a defect, manufacturer fixes the defect, run full diagnostics and sell it again, either way it can not be sold as new so it sells as refurbished. which means it was re-tested to make sure it is in working condition. Also it usually carries a lower waranty 90 days instead of 1 year.
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    Sub: Velodyne DLS-3750R
    Receiver: Pioneer SC-07
    Amplifier: Sunfire TGA5200
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
    CDP: Pioneer DV-48AV
    Interconnect cables: SignalCable analog II
    speaker cables: SignalCable Ultra Speaker Cables Bi-wire
  • grif32
    grif32 Posts: 267
    edited April 2009
    I have had my 880 for about a year now and love it. It works for everything including my PS3. The only thing it wont do for the PS3 is turn it off/on which is no biggie since I have to put the movie in and take it out.
    Harmony one is a little better remote but you can not go wrong with the 880. Very easy to program via your computer.
    (3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
    (2) Panny DMPBDT110 3D Standalone Players
    Panny 60" 3D Plasma TC-60ST30
    Panny 50" Plasma TC-P50G10
    Panny 50" 3D TV TC-P50GT25
    Denon AVR-891
    Harmoney One Remote
    Polk Monitor 70's,Polk CS2, Polk Monitor 40's
  • Blownrx7
    Blownrx7 Posts: 137
    edited April 2009
    No longer an issue.
    Just so everyone knows this was a problem ONLY when they first came out. Logitech made some kind of change to resolve the issue. I bought mine almost a year ago and it did NOT have that problem.
    That being said, the cradle/remote display does give "feedback" to confirm it is correctly set in the cradle.
  • shawn474
    shawn474 Posts: 3,052
    edited April 2009
    The problem with the charging in the cradle wasn't as bad as they were originally thought to be. It's a simple fix by yourself or through Harmony. The problem related to the battery not being seated properly and therefore not making proper contact. You can use a folded up index card to snug it in or Harmony will give you a rubber spacer to place in the remote. Problem solved.
    I have the 880 and absolutely love it. Can't wait until they come out with PS3 capability.
    Hope this helps.
    Shawn
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
