My Record Cleaning Machine
ckphoto
ckphoto Posts: 121
edited April 2009 in DIY, Mods & Tweaks
Here is my attempt at a RCM, I used a old coffee table because I did not want a box sitting in my room or having to store it in a closet. I am not completely finished next weekend I will install sliding doors to hide the vac and supplies. I also need to get a bearing and platter from a direct drive TT so I can install my motor at the moment I am hand powered. Overall I am very happy I am getting excellent results using 3 parts distilled water, 1 part alcohol and a drop of dawn.
Mitsubishi WD-73736
Pioneer Elite SC-05 :D
Xbox 360
Sony PS3 80GB
Velodyne minivee
Rti70s
Csi40
4-Fxi50s
Monster PowerCenter HTS 3600 MKII
Harmony One
1.jpg 133K
2.jpg 96.4K
3.jpg 119.6K
4.jpg 92.3K
Post edited by ckphoto on
  • danger boy
    danger boy Posts: 15,722
    edited April 2009
    very cool... you must have saved yourself about 2K by building it yourself. that's great man. :D
    PolkFest 2012, who's going>?
    Toolfan66 Posts: 18,055
    edited April 2009
    NICE!! What are you using for the vac? and pick up tube? do share..
  • ckphoto
    ckphoto Posts: 121
    edited April 2009
    This is the vac I am using very small with great suction http://www.amazon.com/Shop-HangUp-Mini-Wet%252f-Vacuum/dp/B0001FFM3O
    The black tube coming through the table is actually the end of the supplied vacuum hose I then used a 1/2" PVC elbow which fits in the vacuum hose with a great seal and still allows me to swivel it onto the record. The pick up tube is 1/2" PVC with a end cap I cut a V in the end cap so it sits flush on the record I then cut a 1/4 inch slit down the tube and wrapped in felt. I will take a photo later of the underside of the tube and post it tonight.
    Mitsubishi WD-73736
    Xbox 360
    Sony PS3 80GB
    Velodyne minivee
    Rti70s
    Csi40
    4-Fxi50s
    Harmony One
    edited April 2009
    Thanks i love DIY jobs, would like to see more pics i might just look into doing something like this. BIG SAVINGS!!! Your setup looks nice by the way.
  • thsmith
    thsmith Posts: 6,082
    edited April 2009
    I use the same VAC for my RCM and it does a great job.
    What are you using for the cleaning fluid?
  • Fongolio
    Fongolio Posts: 3,516
    edited April 2009
    Totally cool! Excellent DIY.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • engtaz
    engtaz Posts: 7,669
    edited April 2009
    Great work. Congrats
    engtaz
  • ben62670
    ben62670 Posts: 15,969
    edited April 2009
    Very cool. I need to get one built soon.
    Ben
  • ckphoto
    ckphoto Posts: 121
    edited April 2009
    Thanks everyone for the kind words. I know I am new here and do not post that often but I am good at using the search feature and spend at least a 1/2 hour a day here reading. Before I joined here adding a turn table to my system never even crossed my mind now I listen to records every night and I am loving it.
    Mitsubishi WD-73736
    Xbox 360
    Sony PS3 80GB
    Velodyne minivee
    Rti70s
    Csi40
    4-Fxi50s
    Harmony One
  • ckphoto
    ckphoto Posts: 121
    edited April 2009
    thsmith wrote: »
    I have been using 3 parts distilled water, 1 part alcohol and a drop of dawn dish detergent. I found the recipe here in an old post I think it works excellent leaving no residue on the album.
    Mitsubishi WD-73736
    Xbox 360
    Sony PS3 80GB
    Velodyne minivee
    Rti70s
    Csi40
    4-Fxi50s
    Harmony One
  • thsmith
    edited April 2009
    ckphoto wrote: »
    Yep that works pretty good. I bought a pint of Triton X-114 to replace Dawn. It seems work well too.
  • schwarcw
    schwarcw Posts: 7,358
    edited April 2009
    :)You get an "A" for effort! It looks great. Tell me a couple of things about it's operation please
    Is the turntable motorized or do you spin it manually>
    How do you keep the vacuum tube from lifting the record off of the platter? Weight? lock mechanism?
    How fast does it spin?
    Where does the fluid go?
    What material are you using to contact the surface of the record?
    Do you prescrub with a brush? What type?
    Sorry for the fifty questions;)
    It looks real nice contracts on your innovative thinking!:)
    Carl
  • ckphoto
    ckphoto Posts: 121
    edited April 2009
    schwarcw wrote: »
    At The moment it spins manually I puled the bearing from a belt drive TT.
    I will be changing it to a motorized platter as soon as I get a direct drive TT to scavenge. I am watching a few on ebay so hopefully in the next week or so.
    I do not own a record weight and had trouble coming up with a clamp so I made the pick up wand overlap the label about a 1/2". I then put a double layer of felt on the underside where it contacts the label so it keeps light pressure on the center of the record. I also extended the vacuum slot off the record slightly to improve airflow. It has good contact and removes the fluids completely in 2 to 3 spins without pulling the record off the platter.
    Spins as fast as my hand wants :)
    Fluids go into the canister of the mini shop vac.
    I am using black felt with a self adhesive backing $.94 for a 8x10 sheet at the craft store.
    The brushes I use are from my photo lab they are made from camel hair and seem to do a good job. I do plan on getting the disc doctor record brush.
    Mitsubishi WD-73736
    Xbox 360
    Sony PS3 80GB
    Velodyne minivee
    Rti70s
    Csi40
    4-Fxi50s
    Harmony One
  • amulford
    amulford Posts: 5,020
    edited April 2009
    Excellent job. I like it. I will have to bookmark this one.
  • fast1
    fast1 Posts: 27
    edited April 2009
