Portable air conditioners
dholmes
Anyone use those portable air conditioners,are they less noisy than a window unit?I was wanting something a lot quieter than a window unit for my HT,do the portable ones still have to have a exhaust out the window? thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
my friend has one and his has a 4" in and a 4" out, that both go out side.
PaytonPolk monitor 10B's and 5 jr's
Adcom gfa 5500 and HK/240
Adcom gtp 400
Adcom gcp 600
MusicHall MMF 2.1 TT -
You need a split system. Sometimes called ductless.
Compressor sits outside, and then the heat exchange unit is connected inside.
Lots of companies make them, for example:
http://www.sanyohvac.com/singlesplit.php
http://www.ajmadison.com/cgi-bin/ajmadison/09KS71.html?mv_pc=fr
http://www.amazon.com/Klimaire-Efficiency-Conditioner-Conditioners-Conditioning/dp/B000R7WUQI/ref=sr_1_18?ie=UTF8&s=hi&qid=1238883090&sr=1-18
And I've never seen a portable one be quieter than a good window unit. At least the compressor is outside - with a portable the compressor is inside.
You can get a small one for < $1000 -
Thanks,the only reason I want something different than a window unit is because of the noise level!My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
A split AC unit should be really quiet, I worked around a Sanyo AC and I was assumed it was so quiet.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
