Need audio rack for bedroom set up
BjornB17
Not sure if this is the right forum to post this in but i guess its the closest i could find.
Anyway, I'm looking for an audio rack for my bedroom set up which will have my HTPC, receiver, and cd changer on it. 3-4 glass shelves would do the trick.
The furniture in this bedroom will be dark brown and I'm looking for an audio rack that has this. Glass shelves are preferred but I would consider others as well.
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
Post edited by BjornB17 on
Hi Bjorn.
Try these web sites:
> Salamandar
> Sanus
> Audio Advisor (on-line retailer for Sanus and Salamandar)
Mike____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
+1. Those would be my choices. Sturdy, look good, reasonably inexpensive. I've bought from Audio Advisor a couple of times and everything went very well.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica
