Using the Y connector for my SUB's
Toolfan66
Toolfan66 Posts: 18,189
OK i got another problem. When i use the Y connector for my SUB's i am getting a buzzing sound. is this normal? it would not seem like it to me.
Post edited by Toolfan66 on
  • ben62670
    ben62670 Posts: 15,969
    edited March 2009
    you should have no problems with the Y. Most likely it is a gound loop problem. For a test plug the subs into the same outlet as the source.
    Ben
    Ben
    edited March 2009
    Thanks Ben. I got it, all done no more problems.
