Subwoofer VS. Box Volume
johnacaldwell
johnacaldwell Posts: 1
edited March 2009 in Car Subwoofer Talk
I just bought a Polk MM1204 car subwoofer. The sub calls for .88 cu.ft of space. My older box has internal volume of 1.3 cu.ft. Will the sound be degraded if I place this sub in this box or should I buy a smaller box? Can the old box be "filled" to make it a lesser volume so it will work?
Post edited by johnacaldwell on
  • TNRabbit
    TNRabbit Posts: 2,168
    edited March 2009
    Is the .88 absolute or ideal? You could always put a ball in there to fill space...
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
