Replacement cartridge/stylus
    billbillw Posts: 7,698
    edited March 2009
    For you vinyl newbies, specs on a phono cartridge don't really mean squat.
    The only specs that matter for a phono cartridge are:
    -The output voltage and impedence (to properly match a phono stage to it),
    -The compliance and cartridge weight (to properly match it to a tonearm).
    -The type of stylus and cantilever material. There are obviously big steps up here as quality/price gets higher.
    Other than that, its all pretty much useless info, especially stereo separation.
    A good cartridge is a good cartridge. Look for experienced user reviews. There are a lot of cartridges out there, but the good ones are pretty well known and are talked about extensively at places like AudioKarma, AudioAsylum, HeadFi, and Steve Hoffman's forum.
  • Fongolio
    Fongolio Posts: 3,516
    edited March 2009
    The Denon DL-160 does have extremely low noise and is very forgiving of light scratched LP's. I find the soundstage very wide and deep so seperation is not really an issue. I also have a Grado Prestige Gold MM and I like the Denon more. Digs out more detail without being etchy. I also have a sony new old stock moving coil that comes very close to the Denon for detail but more surface noise is evident. I've also used a Shure M95ED that is very close in sound to the much lauded V15's and it sounds great but slightly less detailed however huge bottom end punch. My 2 cents.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • rayslifecycle
    rayslifecycle Posts: 511
    edited March 2009
    I got the Denon DL-160 for christmas this year - It is amazing - it made my yammy TT sound better then many other TTs I have heard.......Couldn't recommend it enough.
    it is harder to find though - I believe my fiance found it on the bay.
    check out my showcase to see some pics of the cart.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited March 2009
    billbillw wrote: »
    True that.
    My ears really like what I deem to be more separation from my Stanton which the stats conveniently support. My ears also don't hear much background noise using it. I have 4 turntables and 6 cartidges and the Stanton 681 EEE MK III is my favorite. It's specs are quite good too.
    There's lots of love and a bit of hatred (but not much) at audiokarma. AudioAsylum is an asylum, not much shows up at hoffman, and head-fi shows the love too.
    http://www.audiokarma.org/forums/showthread.php?t=125385
    http://www.head-fi.org/forums/f7/stanton-681eee-505-skii-review-327957
    PS.: I do spend a lot of time setting up proper geometry, fastidious cleaning, and my system is tweaked with a Herbie's mat and The Clamp so your results may vary.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • bobt
    bobt Posts: 280
    edited March 2009
    Well a cartridge sound, like everything else in this world of HI-FI....is subjective and up to everybodys personal taste(and ears).
    I've had many over the years, Ortofon,Grado,Pickering,Stanton,A/T. Probably a few more i don't remember. The Pickering and A/T...don't stand out in my mind, so i have to feel they were just ok. The Ortofon..I payed like $150 for and was expecting great things....did not happen. It seemed to be laid back(for lack of a better term), did not bring the soundstage out, maybe..just didn't think it was worth the bucks.
    The Grado on the other hand...was up front....you heard everything that was on the record.....problem is i don't remember if it was a black,green or red....LOL
    Right now i have a Stanton L720EE....just a cheap, middle of the road thing. I'm looking to change my preamp and phone stage, so i didn't buy a $$$ cartridge.
    When i do, i'll probably try the Shure. It's really what your ear likes.....
  • ViperZ
    ViperZ Posts: 2,046
    edited March 2009
    Received my DSOTM yesterday. Also received 'Echoes: The Best of Pink Floyd'. $43 USD + shipping from J&R. My favourite album (Shine on You Crazy Diamond) is on it.
    Can't wait for the Shure to arrive. Put the cartridge on, re-balance/tune the TT for Shure, and I am all set!!!
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • ViperZ
    ViperZ Posts: 2,046
    edited April 2009
    Well, I finally (yes, really finally) got time to install the new cart / re-balance the arm, and listen to DSOTM and Echoes (Time and Shine on You Crazy Diamond).
    First impression: WOW!!!!
    I mean, I knew that the cartridge would make a difference, but not SUCH a difference. The imaging and depth are probably about the same as the old AT cart (which was really good anyway), but the first thing I noticed was the bass extension. I keep hearing people saying that vinyl does not provide good/enough bass. Well, with this cart, it was ALL THERE. Voices and mids in general were pretty good. Highs - I still would like a little bit more - I had to increase treble level on the preamp to get it to the way I wanted it. Overall, I think the investment into Shure M97xE and into the new tt pad was a huge success.
    Test system was 2.1:
    - Dual 1228 with Shure M97xE
    - Cambridge Audio 640P preamp going through Marantz AV550
    - Adcom GFA-6000 amp
    - StudioLab open baffle 3-way speakers
    - Velodyne ULD-15 subwoofer
    Really a mix of the StudioLab 5.1 HT with some components out of the dedicated 2-channel rig, which is still not finished (Maggies are still waiting for me to finish their frames).
    B&W CDM1-SE fronts
    B&W CDM-CNT center
