Csi5 vs Csi A6 Is there much difference?
selkec
selkec Posts: 187
edited March 2009 in Speakers
Hey all. I currently have the Csi5 for my center and the rti150's towers. Im thinking (well my girl friend is...lol) that she wants the wood grain instead of the black. My question is. Is the CsiA6 much better than the Csi5. The 5 is cheaper so if they sound the same I see no need to get the A6 unless one of you know a reason to get the A6. Thanks everyone
Post edited by selkec on
  • Retro152
    Retro152 Posts: 985
    edited March 2009
    selkec wrote: »
    The Csi-a6 is just a "dressed up" version of the Csi5. The same center spec wise.
    Receiver: Pioneer Elite SC-05
    Amp: Emotiva Xpa-3
    Front L/R: POLK Rti-a9s':D
    Center:POLK Csi-a6
    Rear surround's:POLK Rti-a1s'
    Sub: Klipsch Synergy sub-12
    Sony Kdl-46w4100 46" LCD
    PS3
    Audioquest type 4 wiring.
  • mmadden28
    mmadden28 Posts: 4,283
    edited March 2009
    I had both and I'm not sure I could tell the difference, but its possible it may be a tad different, but I think they are probably so close....its likely not worth comparing.
    Physically the 6 is a hair taller than the 5 and its also a half in less deep. Also the cherry finish is slightly different between the RTiA/CSiA series and the RTi/CSi series. To me the new finish is a bit less red, more on the brown side. My CSiA6 center is tucked away so I can't really tell if the difference is noticeable or not with my RTi12's, but matching might be a consideration for some.
    The other major difference, cosmetically, is that the RTiA/CSiA series has the veneer on the front as well. The RTi/CSi had the silver face. (only really matters if you leave the grills off)
    Now on the other speakers of the line?? Its been said the new series sounds better, even if only slightly, and likely because of the new cabinet design. I love the new curved cabinets.
    ____________________
    Pool: Atrium 60's/45's
  • devani
    devani Posts: 1,497
    edited March 2009
    http://www.avsforum.com/avs-vb/showthread.php?t=966590&highlight=csia4
    you won't hear difference, sure they look different if you want to match....
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited March 2009
    They're very similiar sounding centers. I had both a6 and csi 5 and only went with the a6 to match the new rti a series.
  • Dawgfish
    Dawgfish Posts: 2,554
    edited March 2009
    I agree,
    I own them both and can't tell a difference in sound. Go for the deal!
  • Menasor
    Menasor Posts: 283
    edited March 2009
    Like everyone else has said, they're pretty much the same. I've had both, and I think the CSi A6's tweeter is slightly less bright, but not noticeable enough to pay extra for the A6 unless you want to match
    Fronts: Energy RC-70
    Center: Energy RC-LCR
    Surrounds: Energy Veritas 1.0CM
    Subwoofer: SVS PC12-NSD
    Receiver: Onkyo TX-SR705
    Amplifier: Denon POA-2200 w/ Ben's ICs
    Pics of my setup (click me)
  • selkec
    selkec Posts: 187
    edited March 2009
    Thanks for the info. I think Ill hold off untill I find a really good deal since they pretty much sound the same.
