Rear surround 5.1 slanted ceiling placement
Ankhman
Ankhman Posts: 4
edited May 2009 in Speakers
Hi there,
I recently moved, and my new 5.1 home theater room has a slanted ceiling that starts 3' from the floor. My couch will be against this wall facing the TV on the opposite, slanted ceiling wall. I have no problems with placing my Polk front and center channel speakers, but after lots of forum searching I have been unable to find a suggestion for placement/settings for my rear LS/FX speakers. Should I mount them flush on the slanted ceiling (and therefore at the angle of the ceiling) to the left and right of the couch above ear level, or on the rear wall at ear level (can't be any higher because of the slant), or is there something else I'm not thinking of? I am unable to place them on the side walls directly to the right and left of the couch for various reasons. Should I set the speakers to Bipole or dipole? The room is relatively small (around 18x16). I am stumped! I am hoping you friendly folks here at the Polk forums can help me, you've been so great in the past. Please let me know if you need any additional info.
Much thanks!
Jeff~
Post edited by Ankhman on
  • Ankhman
    Ankhman Posts: 4
    edited March 2009
    Hi there! Thanks for the speedy response.
    Hehe yeah, my move was not really a 'by choice' situation. I'm one of the many bankrupt, foreclosed people. So my living situation is very much catch as catch can. This comfortable, slanty room is what I have to work with.
    We haven't moved our furniture in yet, so pictures wouldn't give you a very accurate depiction of where things are situated. We're moving stuff in Monday, at which point I can post pics.
    The whole bankrupt thing means I have very limited cash to work with, so speaker stands are probably not an option at this point. I'm looking for the best wall-mount situation I can come up with in my limited space. I figured since the LS/FX speakers are side-firing, that they might actually work mounted flush to the slanted ceiling with some good wall anchors, but not knowing much about speaker placement (I love my sound but I'm not very informed), I came here for more info. :)
    I'll post pics on Monday eve after we get everything moved in.
    Thanks again!
    Jeff~
  • kuntasensei
    kuntasensei Posts: 3,263
    edited March 2009
    If it's a 5.1 setup, the surrounds are supposed to go on the side walls, not on the back wall. There are no rear surrounds in 5.1. Just sayin'. :)
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • Ankhman
    Ankhman Posts: 4
    edited March 2009
    Hmmmm.. the manual for the Polk LS/FX speakers specifies a side mount and a rear mount solution for the model. Are you sure about that?
  • kuntasensei
    edited March 2009
    http://www.dolby.com/consumer/home_entertainment/roomlayout2.html
    I mean... you CAN mount them anywhere you want. But as far as proper placement for 5.1, Dolby dictates sidewall placement, 90-110 degrees from the listening position.
    Equipment list:
    Emotiva XPA-3 amp
  • Ankhman
    Ankhman Posts: 4
    edited March 2009
    Thanks for taking the time to chat about this with me. :)
    Ok, I've seen that film.. but the LS/FX speakers are side-firing and bi-dipolar switchable. I think they're designed to be used either to the sides or to the back. Here, check this from the Polksters:
    http://www.polkaudio.com/education/tech_article.php?id=27
    So ultimately this is why I want to know if I'm ok mounting them in the bipole position shown in that link, but on a slanted ceiling instead of against a flat wall. The more I think about this I suppose I should just try it and see how it sounds. OR maybe I should just shop at Walmart for a few weeks and buy a decent set of speaker stands for proper side placement.
    In any case, thanks for the feedback!
    Jeff~
  • kuntasensei
    edited March 2009
    If you're happy with them in the rear, that's fine. I was just wondering.
    Equipment list:
    Emotiva XPA-3 amp
  • BMR
    BMR Posts: 9
    edited May 2009
    I have wall mounted LS/fx speakers set in a dipole configuration. They are less than 2 feet behind my listening position and sound great. In case you are interested, I have some (Polk LS/fx) speaker stands that I originally purchased that I am no longer using if you are interested in purchasing...
  • dpowell
    dpowell Posts: 3,081
    edited May 2009
    Dipole is less directional than bipole. Polk recommends dipole for HT. Bipole would be a better option for multi-channel audio like SACD. The higher you can mount the speakers, the less directional they will seem when watching movies. If you have the time, experiment with them on the sides and the rear to see which works best for your situation.
