Room treatments.
Toolfan66
I know that room treatments can get expensive, just looking around the web.
Has anybody done a DIY type of room treatments? If so what have you used?
Post edited by Toolfan66 on
Just to try it, I had two sets of pleated shades and some thick wool type carpet pad. I covered the entire wall behind the TL's. Helped a good bit.
Colored pleated shades make a good wall covering to hide DIY panels. May have some WAF. I have a mancave, so I can do what I want.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
I used Roxul brand mineral wool for my panels and corner traps.Testing
Testing
Testing -
Look at the ones in my sig, OC 705 2" local for $15 each, wife made the covers.Speakers: SDA-1C (most all the goodies)
Mineral, insulation without backing, or rigid fiberglass work best."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
DIY using the OC 703/05 does the job with sound absorption. Make sure that you cover them with a see-through material. Hold the material up to the light, that should tell you.
Roxul safe and sound with custom birch frames. I'm in Canada.
total cost was over $100 for 3 panels(it's fairly nice wood) -
Hey Shinace,
What size are your panels?
Do you have pictures to show us?
$100 for 3 is not bad at all!!! -
Im guessing it cost me $150ish to do these 2 big panels plus 2 small panels and 4 corner traps.OC703/705 is not sold here so I used Roxul mineral wool.The frames for the big panels were constructed with 1x4 pine .Testing
Testing
Testing -
Here ya go.
http://www.polkaudio.com/forums/showthread.php?t=65330&highlight=treatments
Best overall sound improvement I ever made. Of course the room was extremely bad acousticly...
Nick -
I took these pics with my phone just to show y'all. My good arm is broken so the pics are kinda weak.
Like most people, the panels are 24" x 48" (give or take an inch). A 30$ bag of Roxul can do 8 panels. I then used 1/2"(10 ply) russian birch plywood and ripped the frames. The fabric is strecthed to the inside of the frame, then I layed in the miineral wool, and then glued bracing to the back. I paid 80$ for 2 sheets of 4'x4' plywood. This was just enough for the three frames.
Obviously, the cost savings is in the frames.
My floors are hardwood, the walls are plaster and so is the ceiling. The change with the three panels was almost too much for me. Luckily I didn't pull the plug, left them there, and can now enjoy my silky smooth highs.
Canadians: I strongly recommend Roxul as the NRC ratings are amazing. It's better than OC for vocals but not as good below 500Hz. If you're making seperate bass traps, Roxul safe+sound likely outperforms Owens. -
Thanks for the Ideas, I will be doing this. I love the corner traps, i really need 4 of them.
After i finish my TT stand i will move forward on this project.
Larry -
I built panels like those pictured above. I used sound board from Home Depot, 1/2" 4x8 sheets cut to size and covered with black felt from the local fabric store, they worked fantastic and were dirt cheap.If...
Ron loves a film = don't even rent. -
ShinAce,
Very nice job!
I wish I could find a source for Roxul local to me...:( -
Home Depot for us Canucks.
edit: Thanks for the kind words. As far as I'm concerned, the panels are unfinished. I still need to seal the wood and maybe silkscreen some art onto them.
