Room treatments.
Toolfan66
Toolfan66 Posts: 17,980
edited March 2009 in DIY, Mods & Tweaks
I know that room treatments can get expensive, just looking around the web.
Has anybody done a DIY type of room treatments? If so what have you used?
Post edited by Toolfan66 on
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited March 2009
    Just to try it, I had two sets of pleated shades and some thick wool type carpet pad. I covered the entire wall behind the TL's. Helped a good bit.
    Colored pleated shades make a good wall covering to hide DIY panels. May have some WAF. I have a mancave, so I can do what I want.
  • Systems
    Systems Posts: 14,873
    edited March 2009
    I used Roxul brand mineral wool for my panels and corner traps.
    Testing
    Testing
    Testing
  • thsmith
    thsmith Posts: 6,082
    edited March 2009
    Look at the ones in my sig, OC 705 2" local for $15 each, wife made the covers.
  • Face
    Face Posts: 14,340
    edited March 2009
    Mineral, insulation without backing, or rigid fiberglass work best.
  • del44
    del44 Posts: 686
    edited March 2009
    DIY using the OC 703/05 does the job with sound absorption. Make sure that you cover them with a see-through material. Hold the material up to the light, that should tell you.
  • ShinAce
    ShinAce Posts: 1,194
    edited March 2009
    Roxul safe and sound with custom birch frames. I'm in Canada.
    total cost was over $100 for 3 panels(it's fairly nice wood)
  • Blownrx7
    Blownrx7 Posts: 137
    edited March 2009
    Hey Shinace,
    What size are your panels?
    Do you have pictures to show us?
    $100 for 3 is not bad at all!!!
  • Systems
    edited March 2009
    Im guessing it cost me $150ish to do these 2 big panels plus 2 small panels and 4 corner traps.OC703/705 is not sold here so I used Roxul mineral wool.The frames for the big panels were constructed with 1x4 pine .
    RT1.JPG 123.8K
    RT2.JPG 78.3K
    Testing
    Testing
    Testing
  • nikolas812
    nikolas812 Posts: 2,915
    edited March 2009
    Here ya go.
    http://www.polkaudio.com/forums/showthread.php?t=65330&highlight=treatments
    Best overall sound improvement I ever made. Of course the room was extremely bad acousticly...
    Nick
  • ShinAce
    edited March 2009
    I took these pics with my phone just to show y'all. My good arm is broken so the pics are kinda weak.
    Like most people, the panels are 24" x 48" (give or take an inch). A 30$ bag of Roxul can do 8 panels. I then used 1/2"(10 ply) russian birch plywood and ripped the frames. The fabric is strecthed to the inside of the frame, then I layed in the miineral wool, and then glued bracing to the back. I paid 80$ for 2 sheets of 4'x4' plywood. This was just enough for the three frames.
    Obviously, the cost savings is in the frames.
    My floors are hardwood, the walls are plaster and so is the ceiling. The change with the three panels was almost too much for me. Luckily I didn't pull the plug, left them there, and can now enjoy my silky smooth highs.
    Canadians: I strongly recommend Roxul as the NRC ratings are amazing. It's better than OC for vocals but not as good below 500Hz. If you're making seperate bass traps, Roxul safe+sound likely outperforms Owens.
    edited March 2009
    Thanks for the Ideas, I will be doing this. I love the corner traps, i really need 4 of them.
    After i finish my TT stand i will move forward on this project.
    Larry
  • Ron-P
    Ron-P Posts: 8,520
    edited March 2009
    I built panels like those pictured above. I used sound board from Home Depot, 1/2" 4x8 sheets cut to size and covered with black felt from the local fabric store, they worked fantastic and were dirt cheap.
    If...
    Ron loves a film = don't even rent.
  • Blownrx7
    Blownrx7 Posts: 137
    edited March 2009
    ShinAce,
    Very nice job!
    I wish I could find a source for Roxul local to me...:(
  • ShinAce
    edited March 2009
    Home Depot for us Canucks.
  • ShinAce
    edited March 2009
    ShinAce wrote: »
    edit: Thanks for the kind words. As far as I'm concerned, the panels are unfinished. I still need to seal the wood and maybe silkscreen some art onto them.
