bluray audio crackle/pop help
Steven_1085
Hello when using my bluray player or ps3 I hear a crackling/pop sound when playing truehd(low and high volumes) on some blurays (not limited to one speaker). Is there any known bluray player issues and how might one fix this?
Post edited by Steven_1085 on
This might be an issue with your receiver. Which receiver you are using?-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
which blu ray player are you using? no snap crackle or pop should be heard thoughPolkFest 2012, who's going>?
Hi,
I am using the avr-645 and the bdp-550 and the ps3. The ps3 seem to have less crackling. Also the disc I used was Bee movie.
Regards -
maybe try using a different cable for your audio or if you are using a HDMI, then try another one. I think I know the kind of pop's you are talking about.. but I don't know what causes them.
Have you tried doing a Google search for that problem?
you may want to post this question in a AV forum as well.PolkFest 2012, who's going>?
I have googled and people have experienced the same problem but I dont see a mention anyware of the cause or fix.
I have a spare hdmi cable I will give that a try. Also 1 tid bit I tried a non true hd track aka dolby digital and didnt notice the problem.
Regards,
