Tonearm / Cartridge Compatibility
jm1
jm1 Posts: 618
edited March 2009 in 2 Channel Audio
Since there are many of new TT users, I lifted this from a post I had made in another thread. Please review this information if you are looking to make a change your existing cartridge. There is a basic set of characteristics you need to examine as all tonearm / cartridge matches might not work...
Having once had the base Scout and Dynavector 10x5 cart, I can say the combination is anything but dead or dull. I would take someone saying its dead or dull with a many grains of salt as you do not know what the TT was sitting on, the cartridge used or even if the cartridge was properly configured. Maybe the room was dead sounding, maybe the phono stage was lacking in some regard, etc…
When planning your TT and cartridge purchase, you should perform a quick calculation to determine if the tonearm and cart will be compatible. This will reduce your chances of getting a bad combination which may not perform to your standards.
Before I upgraded the 10x5 cartridge for the Scout with the standard tonearm, I performed these calculations to determine if the tonearm and cart were compatible.
SPECIFICATIONS
ZYX Fuji R100 X(H)-SB
- Cartridge weight: 9 (5 cartridge + 4 for silver base weight)
- Compliance: 15 horizontal, 12 vertical
VPI JMW-9 Tonearm
- Effective mass: 7.7
VPI JMW-9 Signature Tonearm
- Effective mass: 9.5
RESONATE FREQUENCY EQUATION
rf = 159 / sqrt ((eff. mass + cart weight + fastener weight) * (compliance))
CALCULATIONS
VPI JMW-9 Tonearm
- Fastener weight: 0.5 (best guess)
- Resonant frequency: 9.9 horizontal, 11.1 vertical
Fall between the accepted 8 – 12 Hz range.
When I was contemplating upgrading to the Signature tonearm, the following calculations were performed:
- Resonant frequency: 9.4 horizontal, 10.5 vertical
The cartridge proved to be a good match on paper. It was also a significant upgrade to the Dynavector 10x5.
I have also found other references which mention the acceptable range should be between 10 - 15 Hz range.
JM1
All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
Arthur Schopenhauer
Post edited by jm1 on
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited March 2009
    Very good subject. Here's a site that may provide some helpful info.
    http://www.cartridgedb.com/tools.asp
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2009
    Great write-up John.
    SCompRacer Posts: 9,121
    edited March 2009
    Good reminder. Cartridge compliance is something new and sometimes experienced table owners don’t think about when shopping for cartridges.
    I said that, but it was with a compliant to arm Shelter, not a Dynavector, and on both a Nottingham and VPI table with OEM arms. For that reason, there are dealers that won’t pair certain cartridges with certain table/arm combinations, no matter what form of isolation the table is sitting on. You may not like the presentation, but there is life beyond the arms some OEM’s supply with their tables.
  • thsmith
    thsmith Posts: 6,082
    edited March 2009
    This is new to me and having trouble using these tools.
    Here is what I know:
    TT is Technics SL-1300, specifications for tonearm effect weight is 23g with 6g cartridge. I assume that includes the 9.5g headshell.
    How do I find or calulate compliance ?
    I just bought a Shure M97xE, hope I have bought something compatible
  • hearingimpared
    edited March 2009
    thsmith wrote: »
    The compliance should be listed in your Shure M97xE specifications sheet.
  • thsmith
    edited March 2009
    Thanks, I looked for it there but will look again tonight.
  • thsmith
    edited March 2009
    ok, I am just not finding the compliance for the Shure 97Xe. Maybe it is called something else. Here is a links to Shures web site with specifications.
    http://www.shure.com/ProAudio/Products/DJPhonoCartridgesAndNeedles/us_pro_M97xE_content
  • hearingimpared
    edited March 2009
    Well if this statement is true, "and stylus tip movement is consequently the most rapid," I would venture to say it is a "high" compliance cartridge.
