10A missing lower frequencies
Lippy1
Lippy1 Posts: 1
edited March 2009 in Vintage Speakers
Hey everyone,
First time poster - not sure if this is in the correct forum. :(
I have a pair of 10A's that I bought in college around 1979 or so, and recently noticed that one speaker does not reproduce any lower frequencies, and one of the bass drivers looks like it is "pulled in" (gasket around the cone is flat).
Is this a crossover problem? If so, can I fix it? If not, what else might be causing this?
Thanks for the help!
Scott
Post edited by Lippy1 on
    F1nut Posts: 51,767
    edited March 2009
    You have a locked driver. Pull it out, on the back you will see a model number. Call Polk on Monday and order a new one.
    Welcome to Club Polk.
  • Driver_King
    Driver_King Posts: 266
    edited March 2009
    If it is indeed a frozen driver, remove it and try out the frozen driver solution in this forum (with link to AudioKarma). Tell us how it works out for you. :)
    Home Theater:
    Onkyo TX-SR805
    Behringer EP2500 for SDA's
    Polk SDA II fronts
    Polk Monitor 5Jr. surrounds
    Polk Monitor 4 back surrounds
    DIY A7-900 and DIY A3-300
