What setting to use for 3.1 setup?
poloman1211
i currently have a 3.1 setup front L and R, center and sub, so i wanted to know what would be the best setting to use on my receiver. my options are 2 ch stereo, 7 ch stereo or surround sound, but there is no 3 ch choice, so what is the best for 3.1?
thanks
thanks
Post edited by poloman1211 on
No Dolby 3 Stereo?
Just set your surrounds to 'none' and you'll be fine. -
i did have a harm/kard receiver that had a "3 stereo" opition
Poloman, what make/model are your receiver&?
Can you configure it to a 2.1 set up? I'm thinking downmix to stereo plus the use of your sub. I use to run like this for awhile until I got a complete 5.1 rig.
Strongly disagree. Run 3.1 unless you want the dialogue to be coming from the sides. A center does a lot of the work. Go into the manual setup and turn your rears off - should be in the owners manual.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
