RTi A1 or RTI A3
edited August 2014 in Speakers
I would appreciate ome input on whether I would be better off purchasing a set of RTi A1 or RTi A3 speakers to use in my setup. I currently own the following:
Fronts: RTi A5
Center: CSi A4
Surrounds: None Yet
Subwoofer: PSW 125
Receiver: Sony STR-DE835 (I know, it's old)
RTi A1's look somewhat small, but then I don't know enough about surround sound to make an informed decision. One advantage in getting the RTi A3's would appear to be that they would better serve as stand alone speakers. That's partly why I would not be interested in the FXi series.
I currently use my set up primarily for watching satellite television and movies on DVD. My setup is located in a 12' x 24' room.
Thanks in advance for your input.
Post edited by 1zingo on
Welcome!
    edited March 2009
    zingo Welcome to CP. Is cost any concern? If not I would opt for the A3 no question it is a better speaker and should give you a little more bass and fuller sound. But the A1 will do surround/side duties very effectively. Both will match up with your front stage nicely.
    I would be asking myself:
    is the physical size difference any consideration for where you intend to place them?
    do I think I may listen to multi ch music? Then I would go with the A3.
    do I plan to move up to a 7.1 setup in the not too distant future? If so I would maybe go with the A1, if I liked the job it did, then get two more for rears. If I felt it was a little lacking, I would move the A1 to rear duty and get two A3's for the sides.
    That's the way I would approach this, then try and go listen to them. I think you would be served well with either one.
    edited March 2009
    I have a simalar set up as you, fronts RTIA5's and the same sub. I have no center yet or rears. I am leaning towards the FXI's for my rears as I think you get more bang surround wise for your buck. I ruled out the A1's,knowing I would just want to relace them later.
    Anyway, good luck
    I think when you get a new reciever, you will not believe how much better your set up will sound.
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
    edited March 2009
    Both are good speakers, The A3's are a little bigger, but as Apphd pointed out, the A3's going to give you better bass and mid than the A1. There is a real difference in sound, the A3's going to give you a richer fuller sound. If you're not interested in going for the FX's then i'd vote for the A3.
    _____________________________________________
    Yamaha 6080 Emotiva XPA-5 CSi A6 RTiA-7's RTi A1's Velodyne DLS-4000R
    edited March 2009
    I've heard both. They both sound fantastic but the A3 has more oomph.
    edited March 2009
    Both are great for surrounds. Look into the fxi a series they're great for surrounds as well
    edited March 2009
    1zingo wrote: »
    Fronts: RTi A5
    Center: CSi A4
    Surrounds: None Yet
    Subwoofer: PSW 125
    I would match your A5's with RTi A1s. They are not as small as you think. I have heard both and have noticed that they are comparable In sound. I included some piks of a old Monitor 30's next to my RTi A3. Huge difference in size. I have A7's and almost wish I would have bought A1's. Reason i bought the A3 was because I thought A7's and A9's would macth up better with them since they are huge speakers. If you can get them cheap than I would say get the A3. I know they sell refurbs for cheap directly from polk. Its just the size of the speaker is HUGE!!!:D
    -Sharp 46" (64U series)
    -Denon AVR988
    -RTi A7, CSI A6, RTi A3
    -SVS SB12 plus
    edited March 2009
    I'd go with the A3's myself. It's a bigger speaker, has better low end extension, and would probably match up with the A5's a little better. Either one will work fine though.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    edited March 2009
    Go with A3 - sounds much cleaner
    Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07
    , logitech 880
    Def Tech Mythos ST :D Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
    2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
    Bed Room: Pioneer Elite VSX-52 , Monitor 50
    Storage-RTi8,CSi5,PSW505,Monitor50
    edited March 2009
    I've owned both, the A3's are much better in my opinion.
    edited March 2009
    Gentlemen,
    I am extremely appreciative of the advice I received from all of you. In light of your comments, I felt reassured enough to snag a set of RTI 1A's off of Polk Direct this morning. Moreover, your positive comments about the RTi A3's were also valuable especially in light of Apphd's comments about eventually teaming these up with a set of RTi A1's as part of a 7.1 set up. This is something I can afford to consider because the savings I achieved through Polk Direct. To date, my complete speaker set has cost about $1,100 versus the $1,950 Crutchfield would have charged me. Although I allegedly received refurbs, they look and sound pristine. So, thanks again to all for helping me out.
    edited March 2009
    I think you'll be very happy with the A1s. I have the same combination -- RtiA5s as fronts, Rtia1s as rears/surrounds and a CsiA6 as center.
    While the others are probably right about the A3s having more oomph and a fuller low end, I saw that you will be using these primarily for TV and DVDs and mine have served me well in this regard. If you had planned to use them mostly for music, then maybe stepping up to the A3s would be worth it.
    The (small) size of the A1s was a big plus for me, as I have a relatively small living room. I also got mine from Polk Direct's Ebay store and I seriously doubt that you can do better -- anywhere -- at this price point. And yes, mine arrive looking and sounding exactly like new loudspeakers. Going on 3 months with these now, I couldn't be happier.
    2 Ch.
    Parasound Halo A23 Amp
    Parasound Halo P3 Preamp
    Parasound Halo T3 Tuner
    Bada HD22SE tube CD Player
    Magnum Dynalab Signal Sleuth
    Magnum Dynalab ST-2 antenna
    polkaudio Lsi9s (upgraded cross-overs)
    MIT Shotgun S-3 Bi-wire Interface Speaker Cables
    MIT Shotgun S-3 Interconnects (3)
    IegO L70530 Power cords (3)
    HT
    Denon 2808ci AVR
    polkaudio RTi A5s (fronts)
    polkaudio RTi A1s (rears)
    polkaudio Csi A6 (center)
    Signal Cable Ultra Speaker Cables
    Signal Cable Analog II Interconnects
    edited March 2009
    1zingo wrote: »
    Gentlemen,
    So how you liking the A1's?
    -Denon AVR988
    -SVS SB12 plus
    edited March 2009
    I Just went through this same decision making process. I found a pair of RTI6's for 199.95 so I ordered those. I am looking forward to getting them.
    I'm sure you'll be happy with the RTIA1's
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
    edited March 2009
    Go for the RtiA3s:D
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
    edited August 2014
    RTiA3 vs RTiA1... RTiA3 wins
    Later on the RTiA3 can be used as stereo bookshelf setup, so they are easier to be sell again if needed.
    RTiA1 are too small for stereo bookshelf setup, and not easy to place behind sofa either.
    FXiA6 vs FXiA4... FXiA6 wins
    Both have similar size and both are easy to place behind sofa.
    None can be used as stereo bookshelf setup.
    then... final round...
    RTiA6 vs FXiA6... I cant see a winner here
    RTiA6 can be used as stereo bookshelf setup (versatile for future, easy to resell)
    FXiA6 are much easier to place behind sofa, and specially design for surround sound.
    edited August 2014
    Kind of late to the party on that answer?
    Main Surround -
Welcome!
Welcome!
