Binding Post
This is crazy! So I am setting up A3's and the one binding post is smaller than the rest inside. It looks like a manufacturing issue; apparently it wasn't hollowed out enough.
I was planning to bi-amp but that isn't an option now. Has anyone heard of this happening? Should I return the speakers?
f: RTi A5
c: CSi A6
r: RTi A3
s: BIC F12
r: Integra DTR 6.9
c: CSi A6
r: RTi A3
s: BIC F12
r: Integra DTR 6.9
Post edited by guinsdan on
Inside where?
Where the bare wire goes, or where the banana plugs go? -
Inside where?
The plug. I actually jacked a plug up a little b/c I wasn't expecting it NOT to fit!f: RTi A5
c: CSi A6
r: RTi A3
s: BIC F12
r: Integra DTR 6.9 -
That's strange.
Did you make sure that the little plastic piece that covers the whole in the binding post plug didn't fall inside? lol
That is weird though, i'm sure Polk CS will take care of you.
Or just exchange them if you bought them locally. -
No need to bi amp those speakers you'll never hear a difference.
Thanks...I figured that but I have OCD and need to try it.f: RTi A5
c: CSi A6
r: RTi A3
s: BIC F12
Did you check inside the plug hole, like metal83 suggested?Political Correctness'.........defined
