Cross Over Setting on SW
Evanguy2004
OK everyone. I am new to this world of Sub Woofers. I just bought a new Polk Audio PSW111 over the weekend at CC for $149.99 (50% off!!). I now have found the setting on my Denon Receiver to boost the DB in the SW channel. This has made all the difference in volume! Now my question is what is the optimum setting for the crossover. I originally set it to 80 hz but I read somewhere if you set all your front speakers to small (I have no rears) you can go higher on the crossover setting. I now have it set to 120hz
Here is how I have my PSW111 set up:
Denon AVR 1706 REceiver
LFE SW Output to the PSW111
All my fronts are set to small
SW Channel DB set ar 5 DB (PSW111 is set at around 50%)
Post edited by Evanguy2004 on
What are your main speakers? Most prefer their SW set at 60-80 if their fronts can handle being set that low. After a while you'll most likely not like the sub as high as 120.
Ben -
Generally, you want to set your sub at or just above the -3 dB rolloff point of the Mains.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
I use the Studio 10 Polk Audio from about 15 years ago as my front L/R Mains. Now that I found the Channel DB setting for the SW, I might take down my crossover of my SW to say about 80Hz from the 120hz. Is that what I am hearing?
120 is too high. A lot of newbs(including me) fall into setting their XO point to high for the extra volume, but it grows old soon for most.
Ben -
Yep, 120hz becomes localized, with my SVS PB13U I find 60hz works best for me and the SDA-1Cs. No sub needed for music thoughSpeakers: SDA-1C (most all the goodies)
Thanks everyone for your comments. I will try lowering my crossover tonight when I get home from work. I initially had it higher (120Hz) because my channel DB on my SW was set at zero (Default setting). Low and behold I find that I can turn up the channel DB on my Denon to like 2DB or 3DB whichhas given me the boost I was looking at. I think the standard 80hz will be good for now.
The problem before was I was at "10" on my volume switch on my PSW111 and I needed to go to "11" (Spinal Tap Humor) :eek: -
OMG...I just set the PSW111 to 80 Htz and I think I just found the sweet spot for my PSW111. Key learning....If you feel like your sub woofer isn't kicking out enough bass find the Channel Db setting on your receiver and kick it up a notch!:eek::D;)
120 Hz is pretty high. You'll often be able to localize audio coming from the subwoofer, which you don't want.
